in clutch can problem? get t gear
Can't get in gear - clutch problem?
Howdy!  Got in the car last night and it would not go into gear (meant I had to run to the football instead!).  Can stick it in gear when the engine isn't running.  If I put it in gear before starting, I can't get out of that gear.  I'm assuming this is a clutch problem, but I haven't noticed any indication of a problem developing.  I drove it for about 80 miles the previous night.  I have, however, been intermittently getting a Service ESP warning on the dash for the past week or two.  It's obviously pretty cold at the moment - I'm not sure if this could have triggered/exacerbated an issue.  Any ideas what the issue is likely to be, and if there's anything I can do to get it in a drivable state so I can get it to a garage?
It's a 2010 2.0 CDTI Elite.  About 40k miles.
Thanks in advance for any ideas.
  AC Compressor clutch broken rlievens 2 4,294 19:th-Sep-2020, 19:01:39
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,257 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Injectors or SCV problem? kartush45 1 4,935 11:th-Mar-2020, 11:08:58
  Electric Window intermittent problem Stanhope 3 7,607 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 8,782 16:th-Mar-2019, 10:29:33
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 19,483 26:th-Sep-2018, 23:50:59
Last Post: everson38
  Gear stick ( broke ? ) Daz21 9 10,877 6:th-Dec-2017, 23:31:24
Last Post: nosteb90
  Clutch adjustment/grinding gears dammfust 1 5,461 22:nd-Sep-2017, 00:03:22
Last Post: mw2299
  Problem with DRL mw2299 5 7,358 21:st-Sep-2017, 07:25:38
Last Post: andiman t
  Astra J Clutch pedal loose abba34 6 13,033 16:th-Sep-2017, 00:11:26
Last Post: slavenK
