| problems engine |
engine problems
20:th-Jan-2017, 22:11:10
hi all question for you all has anyone had an issue with the revs hanging around 1200 -1500 rpm then slowly dropping to idle on 2.0 cdti sri
everything else seems ok i only have a code reader which i shall be putting on tomorrow to see if anything pops up but at a wild guess im thinking throttle body gunked up causing it to stiffen up i only had the car 3 months it has 60k on the clock says full service history but as i havent done this myself its just a piece of paper and i doubt very much the egr system has ever been cleaned thanks for any help
22:nd-Jan-2017, 16:19:50
Never seen that on mine.
23:rd-Jan-2017, 19:49:22
My 2.0cdti is running strangely at the moment. Just wondering if anyone else's is more noisy? Maybe down to the cold.
24:th-Jan-2017, 08:32:18
Mine is a little noisy in the cold.
24:th-Feb-2017, 11:41:49
Anyone noticed a strange pump noise in tic over.
I have the 1.4 turbo and on tic over I can hear a noise coming from the air con pump which doesn't sound normal. I will try and post a video soon. The sound fades in and out with each turn of the belt. Also while on the subject of noises I noticed the car sounds a bit like an electric car when driving over 50mph. Any ideas? Sent from my iPhone using Tapatalk
16:th-Oct-2017, 01:56:14
Hi there was wondering if anyone has had the strange noise on the astra j a20dth engines it's only on start up for 30 seconds to minute seems to be a common kind of issue on these engines, just to see if anyone has any idea before I start replacing belts pulleys and tensioners. It's a similar noise to the insignia that's in this link https://youtu.be/_DnGjvC6JlE
18:th-Oct-2017, 18:14:03
Hi, has anyone had a problem with intermittant coolant loss from the waterpump (1.6 petrol)
the previous owner told me he had to top up the coolant a number of times, he said it had leaked onto the belt and sprayed around the engine bay, he had his dealer look at it 3 times they could not find a fault! I've not seen this, or had to top up coolant yet, any ideas?
11:th-Jan-2018, 16:13:15
(24:th-Jan-2017, 08:32:18)Rusty2009 Wrote: Mine is a little noisy in the cold. Hi, At the manual write if a weather is cold power is reduced to due engine warm. May be you talk about that. I have a parking heater and if weather are under 7 degree, if i don't power it (parking heater with remote control) he powered alone with start of engine for fast warming. Regards |
| 1.7 cdti engine judder in 5th and 6th | ScottN2211 | 0 | 3,322 |
21:st-Oct-2023, 16:27:48 Last Post: ScottN2211 |
| Engine Coolant and remote locking | dm1996 | 1 | 5,825 |
14:th-Nov-2018, 10:19:53 Last Post: Big Dave2 |
| Engine sound | Lukedent1234 | 0 | 5,313 |
18:th-Sep-2017, 09:26:28 Last Post: Lukedent1234 |
| Noise from engine | SI SRI | 8 | 16,180 |
26:th-Nov-2015, 15:17:23 Last Post: monty2000 |
| Engine sounds funny...... Or not | dutton84 | 15 | 15,509 |
11:th-Sep-2015, 09:04:59 Last Post: dutton84 |
| Astra J 1.7 engine chirping and pressure | Jasoncourt | 13 | 21,826 |
11:th-Sep-2015, 07:25:07 Last Post: Rusty2009 |
| Engine Rattling | sheppy1 | 39 | 44,893 |
16:th-May-2015, 09:47:27 Last Post: sheppy1 |
| common problems | tucpal | 15 | 23,681 |
7:th-Mar-2014, 02:07:41 Last Post: Migwell030744 |
| Who read this thread? |
| 4 User(s) read this thread: |
| TheGibs (25:th-Jul-2025, 11:09:31), ImaoCow (19:th-Aug-2025, 00:42:31), dread123 (4:th-Mar-2026, 19:58:26), StickeNZ (14:th-Jan-2026, 05:00:25) |
![[Image: 9nd4_zpsea5fce57.jpg]](http://i179.photobucket.com/albums/w301/tucpal/9nd4_zpsea5fce57.jpg)
![[Image: DSC03659_zpssmtodvyc.jpg]](http://i179.photobucket.com/albums/w301/tucpal/DSC03659_zpssmtodvyc.jpg)
![[Image: Tonto_zps9kmln9qb.jpg]](http://i1054.photobucket.com/albums/s497/Lewis6317/Sigs/Tonto_zps9kmln9qb.jpg)
