changing pads rear
Changing rear pads
Going To attempt this on the weekend, I've neglected my rear brakes to the point I have no material left (approx 2-3mm I think) and my brakes are making one hell of a noise when braking hard.
I'll follow the how to that's on here (great guide, I did the front ones following it) do I need a winding tool? As I've not got one ☹️
(9:th-Mar-2017, 14:55:27)richje100 Wrote: Going To attempt this on the weekend, I've neglected my rear brakes to the point I have no material left (approx 2-3mm I think) and my brakes are making one hell of a noise when braking hard.
Hi richje100, thought i'd return the favour,
if your car has a manual handbrake then you will only need a wind back tool, however if it's electronic, you can only do it with a diagnostic device i'm afraid, if you can wind the pistons back make sure you keep checking your brake fluid as it may overflow everywhere, the easiest way to take some out is with some twisted up kitchen roll that will soak it up out the reservoir
No you don't need a diag tool.
But yes you will need a rewind tool mate.
Thanks guys, my neighbour thinks he might have one down his garage .
Can't undo bottom bolt
have you tried some penetrating fluid ?
http://www.halfords.com/motoring/engine-...rant-250ml
Yep. My spanners seem to be made of cheese aswell. Gave it a good spraying every few minutes and now I'm afraid I will round it off. Looks like a garage job.
(10:th-Mar-2017, 18:16:29)richje100 Wrote: Thanks guys, my neighbour thinks he might have one down his garage .
. You don't need to undo the bottom bolt.
  Changing rear brake discs Big Dave2 3 5,371 26:th-Jun-2020, 18:54:19
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,959 22:nd-Jun-2020, 11:35:40
  Changed Brake Pads, now feels like fronts are sticking Vx-Mad-G 5 11,471 25:th-Jul-2018, 15:44:04
Last Post: Vx-Mad-G
Thumbs Up Replacement discs and pads Iamthestig 3 6,952 23:rd-May-2018, 18:31:42
  Coil spring rear buy used or new caretaker 2 6,738 18:th-Oct-2017, 12:58:05
Last Post: caretaker
  Coil spring rear buy used or new caretaker 4 7,752 18:th-Oct-2017, 11:51:47
  Short rear shocks D92 7 10,624 6:th-Jan-2017, 01:41:20
Last Post: D92
  GTC 2.0 cdti front pads tatters40 1 7,015 7:th-Mar-2016, 22:04:02
Last Post: irmartyn
cpeter53 (19:th-May-2025, 13:15:41)
