buy used new spring coil or rear
Coil spring rear buy used or new
I just had a mot done today and it failed due to driver side rear the coil spring is broken.
Are they easy to change ? Do you buy them new or used from ebay ?
Where do you buy your parts from or do you use the local dealer like General traffic who sells car parts and consumable.
Do you need to change the one which is damaged or do you need to change the pair.
I very hardly drive the car and I and drive carefully and I am very surprised the coil spring is already broken, as the car has only done 38,000 miles and I got the car around 30,000miles. I never noticed when I am driving the car, that coil spring is broken.
Are they common problem in Astra 1.7cdti 2011 5 door.
Rear spring personally I would only buy new and replace as a pair. But that's me
Thanks jpbroad1970 for your reply.
I dont know how i got duplicate thread on here.
  Changing rear brake discs Big Dave2 3 5,346 26:th-Jun-2020, 18:54:19
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,930 22:nd-Jun-2020, 11:35:40
  Front coil springs ericzed1962 0 3,456 11:th-Nov-2018, 21:23:40
Last Post: ericzed1962
  Coil spring rear buy used or new caretaker 4 7,717 18:th-Oct-2017, 11:51:47
  Changing rear pads richje100 8 10,042 12:th-Jun-2017, 13:18:52
Last Post: Astra VXD
  Short rear shocks D92 7 10,591 6:th-Jan-2017, 01:41:20
Last Post: D92
