spring
Well looks like i found out and sorted out the bumpy ride
that i was having the last few months
broken rear coil i went through two on the astra H
so looks like the J springs are no better
[Image: http://i179.photobucket.com/albums/w301/...56fee4.jpg]
Coil spring rear buy used or new
I just had a mot done today and it failed due to driver side rear the coil spring is broken.
Are they easy to change ? Do you buy them new or used from ebay ?
Where do you buy your parts from or do you use the local dealer like General traffic who sells car parts and consumable.
Do you need to change the one which is damaged or do you need to change the pair.
I very hardly drive the car and I and drive carefully and I am very surprised the coil spring is already broken, a
GTC Front Road Spring Query
Hi All, I have a 2016 GTC. I have been undersealing the inner front wings and noticed a piece of hardened rubber block that is attached to three of the coils. It pushes in to place and seems to hold three of the coils a set distance apart. Its the same on both front road springs. Has anyone come across this or know what purpose (if any) they serve ? Any advice would be gratefully received. I need to put the car back together tomorrow and am not sure if I should refit them. Many thanks, Ed
MOT Fail - Broken Rear Coil Spring
So my car failed MOT today due to the left rear coil spring having snapped. Mileage on 66K. (2012 2.0 cdti sri vx-line) I can't say I have noticed that the coil spring was knackered having driven the car etc.
Anyway decided to replace both rear coil springs so I've managed to source 2 Astra J SRI springs (Part No : 13340838) off eBay for 100 quid but have noted in the Haynes workshop manual that I should probably use new shock absorber bolts.
Any
Chris Knott INSURANCE - PRE-SPRING OFFER
Chris Knott Insurance - PRE-SPRING OFFER
Have you ever considered buying a Dash Cam?
Good news if you get a CAR insurance quote from club sponsor Chris Knott by the end of March - you'll be entered in our draw to WIN a Nextbase 522GW Dash Cam with rear-facing camera module and Sandisk 64Gb microSD card (all worth over £200).
In fact we'll even include you in the draw if you
Cubby box spring insertion help
Hi, hope someone can help me. The spring for the handle on the cubby box undrr the steering wheel has popped out. Strange looking thing. Can anyone advise how it goes back in. The drop down flap/door is now permanently open and I have no idea how its's supposed to go in.
