fit view retro dim auto dazzle rear anti mirror
#51
I'll sort the wiring info tomorrow for you & I'll show you where the plug should be.
Ohh thank you, mate! I am browsing workshop-manuals.com and can't find something helpful, as it has infos only for Astra. If you need VIN, just tell me.
(22:nd-Aug-2016, 19:42:16)Phlom Wrote: Ohh thank you, mate! I am browsing workshop-manuals.com and can't find something helpful, as it has infos only for Astra. If you need VIN, just tell me.
What year do you have?
If you could PM your VIN that may help as there are a few changes across the range.
Thanks for sending the VIN.
Ok so it would appear the Insignia doesn't have a Headliner connector.
I've got the following for you.
[Image: INSIGINA%20Inside%20Rearview%20Mirror%20Schematics.jpg]
[Image: INSIGNA%20A10%20Inside%20Rearview%20Mirror.jpg]
****PLEASE NOTE THESE ARE FOR THE INSIGNIA NOT THE ASTRA*****
Just a thought @tucpal has a elite Sig so he maybe able to check the bits out for you in the roof etc.
Thank you, mate! I tried something, it worked for 2 min, then don't know what I did and I couldn't make it work again. Is it posibile I burnt it?
I'll see tonight if I can make it work again.
It should only work at night, did it work ok?
I believe I've done smtgh wrong, cause I couldn't make it work again.
It worked the first time. I covered the sensor in front with some black towel, then with a light a lighted the sensor and the mirror dimmed as it should.
I took power from the wires coming to the reading lights.
[Image: 8b89d63c5e65fe5ec5df474052d240b8.jpg]
Another mirror had these colour codes:
[Image: d486f0ff303e4f8949aa28f0a9ab9757.jpg]
If you've taken power from reading lights you may find they have to be on in order for it to work
I meant from the center light, which has power as long the engine is on, because I tested the conector. I must try again and again...
LE: Rusty, thabk you very much for your help. Today I made it and the mirror works. I had a problem with the conector, but I found another and replaced it.
[Image: 65e248047ea20b9e25962e75be139be6.jpg]
[Image: db1daecd3d70ff7e11d13c2ab06b1fac.jpg]
[Image: 1c51b754fa737dcbf98a7a403e928ea7.jpg]
The only thing I need to do is to find a way to cover nicely the wirring.
And again: thank you!
Hi there,got connection on roof so thinking I just need to get a mirror,seen a few one has sensor on it to automatically turn full beams of , could I use that on and use the cable that goes from roof to mirror with a few other looms if not can I get the loom from connector to lights get new light switch they has auto on it would that work without any vci codes or programming, sorry to bring up trying to get head round a few things before I buy parts etc,cheers??
Just get the auto dimming mirror and loom.
HBA mirror needs programming on IPC and BCM most likely via VCI code (which GM will not supply as it's not on the list).
No probs auto dimming mirror it is then, Cheers..... There's just that much parts out there confusing. While here and need to remove interior lights was looking to replace with black one , back also, it has the motion sensors on it can I use one from any model of astra . ie..Is 3 door different from 5 door connection why's, being a tourer there's a lot of cream roof ,black would break it up a bit, cheers
From any car mate.
Thanks rusty, will get buying much appreciated,cheers
Hi, I'm from Portugal. I have an Opel Astra J Sports Tourer 1.3. I want to mount an auto dimming rear view mirror. I know where I can buy one, but it misses the loom wiring. Where can I buy one? I think the part number is 13293461. Is that right?
(5:th-Apr-2017, 09:37:17)imendes Wrote: Hi, I'm from Portugal. I have an Opel Astra J Sports Tourer 1.3. I want to mount an auto dimming rear view mirror. I know where I can buy one, but it misses the loom wiring. Where can I buy one? I think the part number is 13293461. Is that right?
Part number is 13378813 have a look on ebay etc on main dealer
Is this the right mirror?
[Image: mirror1.jpg]
[Image: mirror2.jpg]
[Image: mirror3.jpg]
(5:th-Apr-2017, 18:29:06)imendes Wrote: Is this the right mirror?
Yes
I bought the loom wiring Part number 13378813 from Opel.
I receive this:
[Image: cabo.jpg]
What is the small connector?
That's for rain/light sensor
(27:th-Apr-2017, 07:03:56)Rusty2009 Wrote: That's for rain/light sensor
Thank you.
I managed to dismount the three panels (easy), but the full console it's not that easy. I'm afraid to break something. Where should I begin in order to take the console out?
Thanks again.
Do You Have a Part Number for the wiring loom mate ?
  Rear view camera MarkAP68 1 4,359 12:th-Sep-2021, 17:51:53
  DAB retro fit for cars with the CD 400 tucpal 203 203,920 13:th-Mar-2021, 13:20:56
Last Post: Morpheus75
  DAB retro fit for cars with the cd500 and 600 tucpal 112 273,737 2:nd-Feb-2021, 12:20:02
Last Post: Bernie2021
  How To Modify Rear Door Card From Car With Elec Windows To Fit Car With Window Winder Jetcolour 5 11,498 24:th-May-2020, 10:19:26
  POWER FOLD MIRRORS retro fit tucpal 121 154,067 19:th-Jan-2020, 09:18:53
  Astra J Sport tourer and OEM rear view camera saarits 47 56,987 26:th-Mar-2019, 23:38:23
Last Post: tzr608
  Retrofit Rear Power point 5 door Astra J Ballinlea 3 15,273 20:th-Mar-2019, 18:13:44
  USB factory retro fit tucpal 20 37,968 13:th-Jan-2018, 12:12:55
4 User(s) read this thread:
Buashei (7:th-Apr-2026, 23:37:51), TonyP (23:rd-Dec-2025, 18:48:24), owenc1 (23:rd-Nov-2025, 23:30:24), N0madd_builds (3:rd-Dec-2025, 14:41:01)
