HOW TO FIT AN ANTI DAZZLE REAR VIEW MIRROR.
You will Have to find a Second Hand Auto Dim Mirror on eBay
If you can get the Small Loom that Goes too the Mirror
and the Console in the Headliner with it Also as it is needed.
If not go to your Local Dealer and Order one as you do Need it
you wont Need the Surround as this Can not be Fitted to the Glass
Unless you Replace
auto dim mirror
Auto dim High beam assist mirror
Here is a brand new auto dim HBA mirror.
£60 collected BH1 4QT or £70 posted.
[Image: https://uploads.tapatalk-cdn.com/2018082...c81f83.jpg]
[Image: https://uploads.tapatalk-cdn.com/2018082...70588a.jpg]
[Image: https://uploads.tapatalk-cdn.com/2018082...f38512.jpg]
Auto Dim rear view Mirror (Meriva B)
Bought myself an Astra J Elite Mirror with the auto dim function, This is to fit on the Meriva B. Just doing my research so i can connect it properly to the BCM to get the signal for when its in reverse.
It came with a rain & light sensor, but from another user on here It needs to have the SD Code on it :( so might try and sell the sensor. Would like to fit auto lights and the rain sensing wiper thing.
[Image: https://www.mk3oc.com/forum/media/meriva....2116/full]
