6 j noise 1 from glovebox
Noise from glovebox - J 1.6
Has anyone encountered a very annoying 'humming' sound coming from behind the glovebox in an Astra J upon starting the engine? (1.6 non-turbo in my case) I can't take the noise anymore...
I've read that could possibly be something wrong with the heater-blower.
Cheers!
sounds like the culprit to me
If your fan is the culprit make sure it is off prior to starting the car and it won't make a noise .
Could it be the motors that set the air direction ? There are two or three of them and they have gears that can wear, try changing the direction setting before starting the car. You will hear these motors operate if you are listening for it even if they are ok.
  1.4T Engine noise Nathan191210 1 3,850 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,510 12:th-Jul-2020, 07:37:10
  Noise when turning engine off Marc_81 6 9,523 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
Photo Grinding rotating noise from GTC? MattDe123 2 6,337 1:st-Nov-2018, 10:30:33
Last Post: MattDe123
  Clicking noise THOMAS123 1 4,791 16:th-May-2018, 08:06:00
Last Post: rlievens
  Engine noise Lukedent1234 3 5,734 21:st-Sep-2017, 10:56:53
Last Post: Rob6606
  Ticking Noise eddier1558 10 28,325 7:th-Sep-2017, 18:25:53
Last Post: eddier1558
  Wheel Noise Following New Brake Pads & Discs GJH1985 5 9,253 24:th-Jul-2017, 10:12:34
Last Post: GJH1985
  Intermittent engine rattle noise Weeman424 1 5,945 21:st-May-2017, 22:07:02
  Dry, almost grinding type noise from front wheels / discs area rbull51 2 9,478 12:th-May-2017, 11:17:58
