HOW TO: Replace Glove Box Bulb Without Removing Glovebox
So i thought id show you guys how to change the glove box bulb for a nice w5w 501 smd bulb, i used one with 12 smds.
Items needed:
Blunt knife of plastic lever
New bulb
So this firstly, how the light switch works, when the pin is extended the light comes on, when the pin is pushed in, the light goes off.
The first step is to use a blunt table knife or other tool to lift down the light from the rear a
Noise from glovebox - J 1.6
Has anyone encountered a very annoying 'humming' sound coming from behind the glovebox in an Astra J upon starting the engine? (1.6 non-turbo in my case) I can't take the noise anymore...
I've read that could possibly be something wrong with the heater-blower.
Cheers!
