Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
It sounds like Turkish.
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
I would say you would need to make some sort of module that will include,
A timer (this would need to have an adjustable setting as well).
12v constant power feed
12V ignition feed
Ground
Reverse input
Mirror up Output
Mirror up input
Mirror Down output
Mirror Down input
Trade Count:
( 0)
Threads: 3
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
with an arduido its possible to do it, but want a cheap and simple solution lol
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Came across this
£141 shipped.
Bit on the expensive side if you ask me.
http://www.kptechnologies.com/products.php#/13
Trade Count:
( 0)
Threads: 3
Thanks Given: 0
0
Total Feedback: 0
well an arduino its cheaper than that...
but that expensive is for both mirrors, i think this is only needed on the passenger side
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
I found a cheap way to do this but it needs some more test to be donne .
[video=youtube;JttYpRQ7T54]https://www.youtube.com/watch?v=JttYpRQ7T54&feature=youtu.be[/video]
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Looks good mate.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
that is looking promising
Trade Count:
( 0)
Threads: 3
Thanks Given: 0
0
Total Feedback: 0
you just have now to replace the switch with the power on of the reverse light or something like that...
nice work pal
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
After a lot of test and adjustment with the module i manage to make it work , but it has some problems with the adjustment of the mirror when the car is working and when the car is not working , so im working on a new module .
[video=youtube;7tHyY7qgs5s]https://www.youtube.com/watch?v=7tHyY7qgs5s[/video]
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Looking good
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
Awesome work mate, cant wait for this to be Able to use :-)
Trade Count:
( 0)
Threads: 3
Thanks Given: 0
0
Total Feedback: 0
this mod should be factory because its so usefull...
keep up
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
Lol yea it should be let us know when its ready as i need a module still as rustys old one didnt work in my car :-/
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Total Feedback: 0
What kind of problems do you have Z8083?
Iam still thinking of set up such a module, but I don´t want to make it time based.
I will try to use a reference. The reason is simple: If you move the mirror manually with your fingers,
all the time based functions will no more work for the new position. That´s why I did not set up
such a module already.
If anyone have some ideas, just let me know, I will try to figure it out.
Jens
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
My module is based on a simple timer circuit with transistors but I get different times because of different current when car is charging the battery same problem as kp module also in quick reverse mirror loose adjustment so delay must be add, I think only time based module is our solution to keep the module cost low I don't know yet my free time is to limited my mind has stuck. Jens your idea is like memory mirrors but I think memory mirrors have double wires for axis .
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Total Feedback: 0
Hi Mate,
yes, the time based solution is the only solution. I found out that the mirrors of the Astra didn´t have a 5V reference signal,
thats why you won´t get memory seats for the Astra. The Insignia mirrors still deliver the 5V reference. With this reference
it is very easy to set the mirror 100% onto the right position.
Iam thinking of a module with microcontroller and a current sense circuit. It must have a balance counter for up/down (like a fader).
For example the highest position have 2048, the center 1024 and the lowest position 0. It must also count when you do a manuel
setup of the mirrors with the switch for up/down. I believe this all would not be the big problem. The only problem will be if
you change the position of the mirror manually (without the switch), for example when cleaning the glas or while ice scraping.
If I will do a circuit it would be mounted near the mirror switch, because all wires you need are over there.
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
3:rd-Jul-2015, 21:48:26
(This post was last modified: 3:rd-Jul-2015, 21:49:52 by z8083.)
It's been a long time but i finally found time to finish v2 module , adjustable time for up down and delay on up know i need to solder circuit on plate and test it on car to see how it works . This is a simple 555 timer circuit .
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
Whats the price expected to be of the V2?
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
3:rd-Jul-2015, 22:31:58
(This post was last modified: 3:rd-Jul-2015, 22:37:16 by z8083.)
I will share the circuit diagram for free , after test and if everything is working fine . I'm not making this for massive production or money it's just my hobby and a small contribution to this amazing forum .
Ps: the price for materials I think it would be from 20 to 25 euros max .
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
looking good and thanks for the info you look like your getting this sorted
keep up the good work
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
3:rd-Jul-2015, 23:36:38
(This post was last modified: 3:rd-Jul-2015, 23:49:06 by bhalay207.)
I once had the privilege of driving an Aston Martin (sadly not permanentley). When you put it in reverse the left hand mirror goes down so you can see the kerb when reversing. When you took it out of reverse, the mirror returned to the original position. Something I've always thought was a great idea.
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
Nice mate :-) cant wait for this, will deffo be placing an order :-)
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Car: Astra J Vx-Line
Sex: Male
Total Feedback: 0
Sorry to dig up an older thread, anyone got any idea where I can get the folding mirrors? I'm assuming my standard mirrors don't already have the motors to make them fold in
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Best place to look is eBay or local scrap yard
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Cheers, had a gander on eBay and its short of £200 for the pair, gonna try a scrappies and see what they've got.
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Remember that if/when you fit them, they don't close when you press the lock button. There is a module available for around £50 which makes them fold in when the car is locked but I'm not sure they work with retro fit.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
£200 is about the right going rate
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Module works with retrofit too still all wires up the same.
As Tucpal has said it's about right go and ask a dealer how much they want (make sure someone is behind you to to catch you.)
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Ahhh, that's good to know. I might get myself one of those modules.
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
There's so much that I want to do, but everything costs £££! I think I'll have a remap next.
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Me and you both. My biggest one I want is an xp kit but getting a genuine one is like hens teeth. I think going to have to build it up slowly piece by piece
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
What about the vx kit or an irmscher kit, plenty of those around
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
I mean the Vauxhall kit. Maybe it's not called the xp pack anymore I don't know. Irmscher you say... This has got my attention lol. Tell me more
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
27:th-Oct-2015, 11:00:27
(This post was last modified: 27:th-Oct-2015, 11:05:03 by Nemo.)
Have a gander at this mate
http://irmscher-direct.co.uk/40-exterior-styling
Or buy the set here but they don't include the sills
https://www.lmfvauxhall.co.uk/Irmscher-S...tra-J.html
Or here but I don't think this one is irmscher
http://www.vauxhallsuperstore.co.uk/cate...aturedDesc
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Oh god the price
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Haha, yeah there is that
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
I've got a seller who doesn't know if the mirrors he has for sale are motorised or not, how can he tell?
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Id imagine more wires going into them
Sent from my SM-T805 using Tapatalk
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Id say they look standard going on the cable but i could be wrong! Ask him to fold them in. If they make a loud clicking noise, almost like they're snapping it could indicate they are power mirrors.
Trade Count:
( 0)
Threads: 63
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
The mirror plug would have 7 wires if there the folding type
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Cheers guys
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: 2010 Astra J 1.6 SRi
Sex: Male
Total Feedback: 0
Hi im looking to do this mod just quick question how does the cable from the body loom connector feed back into the door as its all sealed and if you make a hole in it water is going get in and the wires trapped as the door closes didnt show how it was done on the photos ive probably missed something.
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
You fit all the pins into the plug so it's still waterproof.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
(5:th-Feb-2016, 16:28:18)Rusty2009 Wrote: You fit all the pins into the plug so it's still waterproof.
Sent from my iPhone using Tapatalk Sorry i meant once you have connected to the body loom closed the pink connector then were does the cable go do you feed down with all the other wires into the door as it looks sealed thats the bit im not sure on.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
you just make a pinhole and feed the wires through the rubber boot
the seal with glue just make sure the small holes are facing down
never had any issues with this as the tiny holes are inside the door
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
5:th-Feb-2016, 18:16:31
(5:th-Feb-2016, 18:05:31)tucpal Wrote: you just make a pinhole and feed the wires through the rubber boot
I get it now will be easier when i come to actually do it thanks for all replies and help
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
do the pins on the body loom connector just push in as i am in the middle of this retrofit ive checked they are the right way round they go half way in and stop i cannot get them to push right in cheers
