13:th-Feb-2015, 14:01:01
Does anyone know if the rear Griffin Emblem badge is stuck on or clipped on? I really want to remove it.
Tags |
removal emblem griffin rear |
Rear Griffin Emblem Removal
13:th-Feb-2015, 14:20:20
it is stuck on with 3m tape but there is also two tabs on the griffin
so if you remove the badge there will be two tiny holes on the boot.
13:th-Feb-2015, 14:33:30
Are they very noticeable or will they have to be filled etc?
13:th-Feb-2015, 14:43:39
filled as they stand out
other option is to do the background black but this only works on light color cars
13:th-Feb-2015, 14:49:27
My car is technical grey so it wouldn't make any difference. I've been told to use plasti dip to spray it.
13:th-Feb-2015, 14:58:01
you can do PlastiDip is fine but pealing the inlay bits out is not that easy.
13:th-Feb-2015, 15:11:13
[MENTION=52]Dicko[/MENTION] did his griffin black sure he Plastidip or wrap it.
13:th-Feb-2015, 15:23:01
Could I not remove it, respray it and then put it back on?
13:th-Feb-2015, 15:33:37
Yes but you will need sum new 3m tape to stick it back on but if you do remove it I recommend wrapping it for a better finish
13:th-Feb-2015, 15:36:37
I may just take it to the body shop for them to do.
13:th-Feb-2015, 15:41:56
You can buy a new one from eBay etc then spray or wrap the new one that way you have the tape already on the back just heat the old griffin with a hair drier and use an old credit card to get it off then remove the old tape that will be left over on the car and the griffin with silicone remover or tar remover
5:th-Apr-2015, 11:40:01
How did you do your background Tucpal?
5:th-Apr-2015, 17:32:20
i made a template from an old badge i had and then cut it out and then used the stencil on some gloss black wrap
5:th-Apr-2015, 22:54:14
To undo the tabs to take badge off how do you that? Is it the case of taking plastic of boot door inside?
Lowering springs identify front rear | martinpe68 | 1 | 1,812 |
12:th-Sep-2021, 15:22:37 Last Post: Rusty2009 |
Astra J Rear Bench Seat Clip. | MrScottyMan | 1 | 1,901 |
24:th-Jan-2021, 14:44:22 Last Post: Jpbroad1970 |
Easy removal of glowplugs? | Euroshopper | 1 | 1,938 |
13:th-Nov-2020, 16:21:11 Last Post: eatmybogbrush |
Rear diffuser | Elad1962 | 3 | 2,576 |
29:th-Sep-2020, 22:14:18 Last Post: marktourino |
BiTurbo Rear Bumper | Dudderz | 3 | 2,556 |
5:th-Jun-2020, 19:49:44 Last Post: Jpbroad1970 |
Rear Bumper PN 13346637 | Jonnymac07 | 1 | 2,238 |
13:th-May-2020, 14:56:05 Last Post: paula9568 |
Rear brake pads and discs | everson38 | 4 | 3,762 |
28:th-May-2019, 10:53:57 Last Post: Big Dave2 |
Small glove box removal | chrisb2511 | 7 | 6,339 |
5:th-Mar-2019, 13:14:03 Last Post: Rusty2009 |
electric rear windows | marky79 | 5 | 4,167 |
11:th-Jan-2019, 09:04:32 Last Post: Rusty2009 |
Rear Light Replacement (Need Advice) | A.ROD | 2 | 4,989 |
17:th-Dec-2018, 19:17:48 Last Post: A.ROD |
