it with light dash through yellow lock car on
Yellow light on dash - car with lock through it
just been running kids around tonight and when daughter got in car and I went to start car the yellow light on the dash with the car and lock through it flashed and car wouldn't start...removed key and tried again and started no problem...I know this is the immobilizer but is it doing this because the battery in the key needs changing or is it something completely different??
I had this happen a couple of times or it will start then cut out.
ive not got to the bottom of it and no fault codes are stored, I changed the battery in September at 2yr service it did it once since then.
think I will swap battery and see as I cam across one in draw other day
if its not that it could be the chip just not being picked up
thanks guys
try the other key for a bit and see if it goes away
will do
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,983 2:nd-Feb-2021, 21:12:47
  DPF REGEN LIGHT Starie 113 146,637 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,887 11:th-Feb-2020, 13:01:57
  Dash cam recommendations Telsun 12 10,986 16:th-Mar-2019, 15:26:08
Last Post: Dooks
  Rear Light Replacement (Need Advice) A.ROD 2 7,456 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 16,940 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 9,142 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Rear fog light bulb ID jl47 0 5,601 15:th-Dec-2017, 15:24:34
Last Post: jl47
  Airbag light always on? Ssss 12 15,212 5:th-Oct-2017, 10:50:28
  Lock/Unlock buttons AlanMac 8 9,418 29:th-Aug-2017, 22:20:47
Last Post: AlanMac
