  • 1 Vote(s) - 4 Average
new clicking noise
New clicking noise
Anyone throw any ideas at me.
My brakes are noisy so I'm going to change the discs in a few days.
But when I stop driving forward and reverse say onto my drive when I brake I hear a click like something has become unstuck.
Only happens when I reverse from moving forward and only does it once.
Doesn't do it when I go from reverse to forward but when I reverse again.
I've take the wheel off to see if the disc plate is rubbing or the pads not sitting right but seems ok.
Anything to look for when i get the discs off?
cv joint i had this problem also the drivers side seems to be the problem
I was think a joint of some sort. Long shot but covered under warranty? Or cheap enough and easy to do yourself whilst the wheels are off?
Can't see it being covered under warranty you can but try.
What about fixing it yourself? They cheap to buy or am I look at a huge garage bill?
get an independent garage to check it out
if it is the cv joint then get a price to fix it from them
or just by the complete shaft second hand it may be cheaper just to swap it over
but new prices are very expensive for the whole shaft
but not going to the dealers will save you money
have a read of this mate
http://www.vxoc.org.uk/forum/Thread-CV-J...RIVE-SHAFT
Full drive shafts with cvs cost about £90 delivered 2nd hand or about £690 from vauxhall
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,125 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 1,043 8:th-Sep-2025, 21:22:49
Sad Chirping noise Zaf312 1 1,976 7:th-May-2024, 07:34:19
  High pitched noise (Astra OPC J) maximame 0 7,084 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Electrik brake noise!! blacknik 1 6,837 24:th-Feb-2020, 08:57:02
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 10,759 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  Strange noise from passenger side when driving slowly/stationary and just taking off irishastraowner 3 7,878 16:th-Mar-2019, 09:34:36
  Astra J 2.0 cdti noise on cold start up Iaintruten 3 10,777 17:th-Jan-2018, 17:26:31
Last Post: Iaintruten
  Water Noise Sloshing sheppy1 22 33,783 15:th-Oct-2016, 11:16:57
Last Post: andy2174
  Whirring noise richje100 13 24,364 20:th-Mar-2016, 15:32:00
Last Post: Jj0063
Steve1982 (8:th-Sep-2025, 20:56:27)
