| Welcome, Guest |
| Forum Statistics |
» Members: 12,317
» Latest member: lar77
» Forum threads: 4,566
» Forum posts: 49,709
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| Sports Tourer DAB+ on Android Headunit |
Posted by: MikeyP247 - 14:th-Oct-2019, 16:21:49 - Forum: ICE
- Replies (2)
11 plate Tourer with CD400 factory option - now running an Android W072 headunit.
I have the factory DAB cables in the drivers footwell, so assume I have the lead that runs to glass aerial built in (drivers side in Tourer).
I know there is an amplifier that fits to this with FAKRA cable connector.
Wanting to know:
If the wiring runs from the footwell to the rear and location of plug in loom (above window, below trim etc).
If it is, can I use this cable (with an adapter loom up front, from a USB powered Android DAB+ unit) to run a factory amplifier (does it power it). Alternatively - what options do I have to replace the roof mounted (standard FM - not shark fin) aerial and how would I connect/power that?
Cheers in advance for any suggestions or info.
| New Astra owner |
Posted by: Nathan - 13:th-Oct-2019, 09:18:16 - Forum: Introduction Area
- Replies (5)
Hi new to the site new astra owner, and id like to upgrade my cd400 to get the satnav feature any tips would be welcome
| ariel amp |
Posted by: marky79 - 11:th-Oct-2019, 20:48:38 - Forum: ICE
- Replies (1)
hi all,
can any one tell me if the ariel amp is built into a cd400 or is it separate, if it is separate is there a power outlet from the stereo iso plug
that switches the ariel amp on.
the reason for this is I have changed the stereo head unit for an after market one, since changing it the radio reception is not as good.
| Radio |
Posted by: Flick19191 - 7:th-Oct-2019, 19:28:30 - Forum: Electrical
- No Replies
Hi so have the standard radio in my gtc and wondered what people’s preferred tone setting eg treble mid and bass
| Splitter |
Posted by: Flick19191 - 6:th-Oct-2019, 08:56:37 - Forum: Astra-J/GTC
- Replies (3)
Hi might be a daft question but will a splitter spoiler and door sills for a gtc vxr fit normal gtc thanks
| cascada |
Posted by: jazzy2019 - 3:rd-Oct-2019, 15:52:03 - Forum: Medium cars Astra, Cascada, Vectra, Monaro & Insignia
- Replies (1)
driver side heated seat only works for 5 mins then turns off have a gm 13442703 plug connecter kit but no wiring diagram or location of connector do i have to take out the seat ?
2013 cascada elite
thanks in advance
| Now unable to change tracks over usb? |
Posted by: GHOSTFAULT - 2:nd-Oct-2019, 12:35:06 - Forum: Astra-J/GTC
- No Replies
Hi all, since updating my iPhone X to iOS 13 i've been unable to change tracks using the car's media controls.
I've got an Astra J SRI (2010) with satnav. The phone uses Apple Music, via USB for media and charging and has worked fairly flawlessly until now. The tracks will play, and I can browse playlists and select tracks, but once in a playlist, I try to skip a track and it will attempt the skip, then continue playing the current track.
Has anyone else had this issue, or any ideas on a fix for this? Any help would be appreciated!
