» Members: 12,338
» Latest member: Griff81
» Forum threads: 4,563
» Forum posts: 49,693
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Thumbs Up Vibe microamp, will it fit behind headunit?
Posted by: s_p_a_r_k_e_s - 7:th-Jan-2020, 02:32:47 - Forum: Astra-J/GTC - Replies (3)
Alright people, first post on this forum! Recently purchased a 2013 GTC VXR and wanted to install a vibe microamp behind the factory headunit but not sure if it will fit? Anyone got any experience with this? Was also going to add the Vibe micro sub amp to power a space saver sub at a later date as well. Thanks in advance
  Tree algae around shut lines & Inside condensation
Posted by: Vx-Mad-G - 6:th-Jan-2020, 14:26:11 - Forum: Detailing - Replies (4)
Just after a bit of advice here please.
We have a white Astra-J, and have noticed the last couple times I have washed it that around the ***** lines I get loads of dirt splutting out, especially when jet washing ot hose piping.
I have also notices some greeny tree algae around the tailgate shuts, especially around the top side.
Whats the quickest and most efficient way to get rid of this without splashing the inside of the car?
In addition, im notiticing the inside of the car getting lots of condensation, and when its icy outside, even surface ice on the inside of the windscreen.
There is nothing wet inside the car, seats are dry, carpets are dry, but it just baffles me.
Can anyone help with both issues please?
Thanks.
  Car unlocked and front windows half down.
Posted by: Multiskilled - 3:rd-Jan-2020, 00:13:43 - Forum: Electrical - Replies (4)
Hi, just gone out to find car Astra j 1.7 cdti Ecoflex with front windows half way down and doors unlocked.
I've searched this site and two other Vauxhall sites as I'm sure I read a post from someone with the same problem, to no avail. Any one come across this fault before or can direct me to the the relevant post. Thanks.
Sent from my BV6800Pro using Tapatalk
  2014 Astra 2.0L 165 HP F40 gearbox quantity of oil??
Posted by: Kpal11 - 31:st-Dec-2019, 01:21:54 - Forum: Astra-J/GTC - Replies (3)
  • Hi all,
I have searched around on so many forums now and unable to find a definitive answer as I have heard rumours of vauxhall overfilling the F40 gearbox so I have heard it holds 2.4L, 2.6L, 1.9L, I dont have a clue how much is in thereor whether should be putting in less than what I get out because that what I have seen on a few forums. Would really appreciate some guidance on this!! All I do know is I will be using Redline 75W-85 GL04 oil for it... but how much of it??? ??
Thanks for the help!
  Intermittent low loss of engine power
Posted by: Mark72 - 27:th-Dec-2019, 21:23:25 - Forum: Mechanical - Replies (2)
Hi all hope you’ve all had a great Christmas.
I’m experiencing a strange fault/ feeling with my 1.7 Cdti Astra.
At times it feels like the engine is a bit flat and other times it’s normal, I have also noticed a very slight hesitation under normal acceleration. It sometimes feels like a non turbo engine. No apparent leaks on the pipework and no engine management light on. Has anyone had any experience of similar issues, I’m thinking either the turbo’s on its way out or the boost pressure sensor or mass airflow sensor playing up.
Thanks in advance.
Mark
Wink Re gen light
Posted by: Kiel0777 - 26:th-Dec-2019, 13:36:18 - Forum: East Midlands - No Replies
Hi new to the forum anybody know anyone who can fit me a regen light?
  code 54 water in fule filter
Posted by: Tedwalking - 26:th-Dec-2019, 09:43:47 - Forum: Electrical - Replies (1)
I have a problem with my 2012 Astra gtc 1.7 cdti sport 40.000 miles I have owened it for about 6 months now and all is good except that about 6 weeks ago code 54 WATER IN FUEL FILTER came up and then it whent a way but in the last 2 to 3 weeks it comes on at each startup, then after 5 mins it has gone off, So I decided to change the fuel filter the car seems to go a lot better but I still get CODE 54 COME UP each time I start up, can anyone tell me what it could be and what to try next. By the way I did not find any water in fuel filter when I drained it.
Thank You
Ted
  CV joint?
Posted by: umognog - 23:rd-Dec-2019, 20:11:41 - Forum: Astra-J/GTC - Replies (9)
Evening guys and dolls.
Going to get the J in the garage asap but with the time of year... It will be a couple of days.
So randomly, it starting knocking from the offside drive wheel tonight. When I say knock, this is like someone with a little hammer hitting at a regular interval, not a tick or a click.
It is into happening when it's in gear and under load accelerating.
I'm thinking drive shaft/CV combo?
  Can seem to locate oil filter
Posted by: Bigwillbo - 20:th-Dec-2019, 04:31:07 - Forum: Servicing - Replies (1)
Hi guy I have a astra 1.6 ctdi sri tourer 2015 and I'm going to change the oil on her but can't seem to see the oil filter anywhere. Am I being stupid or is it hidden out of sight. Any help would be Cheers.
[/list]K Rotfl Hi
  New Fuel filter. Wont start
Posted by: SALMHAGE - 18:th-Dec-2019, 19:20:54 - Forum: Astra-J/GTC - Replies (1)
Hi.
Did change fuel filter, dident fill up de filter with diesel and now i have problem starting.
Someone post a picture of a sqrew to turn a half turn. That worked last timme but now the picture is gone.
Someone know what screw? Smile
/Astra j 1.7 CDTI
