| Welcome, Guest |
| Forum Statistics |
» Members: 12,317
» Latest member: lar77
» Forum threads: 4,566
» Forum posts: 49,709
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| Dpf levels |
Posted by: Kiel0777 - 30:th-Apr-2020, 15:24:27 - Forum: Mechanical
- Replies (2)
Dpf says 131% on opcom and over 6k miles since last regen :/
| Newbie |
Posted by: BazMB - 30:th-Apr-2020, 12:09:53 - Forum: Introduction Area
- Replies (2)
Hi all, hope all well & safe. Daily drive 2012 Meriva B 1.4t 140 - stock with a few cosmetic upgrades from other VX models....future mods include uplevel DIC, navi retrofit & afl's (but read no longer supported?)....anyway super site for technical info & help...cheers!
| Astra J 1.6 SIDI A16XHT/A16SHT |
Posted by: foxydimsi - 30:th-Apr-2020, 09:08:43 - Forum: Astra-J/GTC
- Replies (1)
Hello guys.
I am sorry if someone already questioned about this. So i own Astra J 1.6 turbo SIDI 170hp with code A16XHT. I wonder if the "updated engine A16SHT with 200 hp is the same , but only different software. I talked with a guy in the local dealership and he told me it's just software " these extra 30hp" . Sooo, can somebody give more info about this .
| sump plugs |
Posted by: andyp - 27:th-Apr-2020, 14:14:42 - Forum: Astra-J/GTC
- Replies (5)
Hi now I have changed a lot of oil in my time, and have always renewed the sump plug washer or o ring, but just lately I have come across always renew the sump plug ? when doing an oil change, on web sites and tv shows, any ideas where this is coming from or opinions on the subject, me I think I will stick with renewing just the washer/o ring
| Aftermarket headunit malfunction |
Posted by: prtklmb - 26:th-Apr-2020, 19:58:18 - Forum: Astra-J/GTC
- Replies (2)
Anyone there having similar problem.
I had recently installed rear view camera that fits where the rear light is, just above the number plate (Astra elite 2011). All wires set up and camera triggers on when in reverse gear.
The problem - the button on the car stereo faceplate (Volume and option) & steering wheel control works perfectly prior the use of rear camera. Once I active the rear camera via the reverse gear the screen views the rear and after disconnecting the reverse gear the camera turns off bringing to normal screen, but I cannot use the volume and option button in head unit (Sony XAV AX3005DB)nor steering wheel. Only home button works in the head unit, the music can be changed via the touch screen.
Anyone have any idea what is causing this? Seems like something gets switched off inside the head unit.
If I turn the ignition off and on again, I can use the volume, option button and steering wheel function.
| GTC BT CD400+ |
Posted by: ac1212 - 25:th-Apr-2020, 13:31:48 - Forum: ICE
- Replies (1)
Hi all
I'm purchasing a 2014 GTC CDTI on Monday and upon testing the bluetooth it only has functionality for phone calls and not to play audio. The Stereo is a CD400+ I believe.
How would I go about upgrading this to play bluetooth audio and be able to use the steering wheel controls with this? I'm not after a new unit for navigation/parking cameras or a nice touch screen etc. Just want to be able to play BT audio and use the wheel controls with it on the same unit I have now.
I'm also completely useless with fitting stuff so would require someone to do it for me, I assume you'd need some new cables and to maybe programme the unit (you can tell I'm an absolute amateur). If anyone has any ideas and how much this would cost for someone to do it all and any recommendations for who's the best person to do this, I'd greatly appreciate it.
