| Welcome, Guest |
| Forum Statistics |
» Members: 12,288
» Latest member: DawidTD
» Forum threads: 4,564
» Forum posts: 49,699
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
quickheat retrofit WIP
Last Post: obsidian
26:th-Aug-2025, 19:15:09
» Replies: 10
HOW-TO LED DRL Error free...
Forum: Lighting How-to's
15:th-Aug-2025, 19:10:30
» Replies: 222
Navi950 retrofit in Zafir...
Forum: Large Cars Zafira, Mokka & Antara
Last Post: Happy25
11:th-Aug-2025, 18:41:42
» Replies: 4
cd400 pinout
Forum: Site updates
5:th-Aug-2025, 19:02:11
» Replies: 3
| Wheels |
Posted by: 3_crispies - 22:nd-Jan-2021, 21:18:07 - Forum: Astra-J/GTC
- Replies (1)
Looking at changing to Gtc but dont like the 20 inch wheels as do high mileage. What is a used set worth with 5mm tread and can I fit standard sri 17" alloys when I find some.
Sent from my SM-A405FN using Tapatalk
| Navi 950 with touch screen info |
Posted by: Rusty2009 - 13:th-Jan-2021, 16:59:56 - Forum: ICE
- Replies (9)
The info was originally found via YouTube and https://www.clubgsispain.com/
But once we saw it @Jpbroad1970 & myself got stuck in & started playing.
We can enable touch screen rear camera and DAB+ with a Chevy theme quite nicely.
For this you need a screen with the following part number 22851302
There are 4 extra wires needed for touchscreen as detailed below, The white & blue are shielded with the black being the drain.
Video of touch screen working.
Please note the Android auto / car play is an added feature which is a separate module and not enabled via just adding a touch screen and the programming to enable touch screen.
| Electric windows |
Posted by: Refuseman1960 - 9:th-Jan-2021, 12:19:39 - Forum: Astra-J/GTC Common Problems
- Replies (1)
Periodically the front windows on my Astra open either halfway, or fully. The car is always locked and windows are fully closed when left. Has anyone else experienced this, or have any suggestions? My local garage have not heard of this before.
| Front PDC wiring diagram |
Posted by: milozic - 8:th-Jan-2021, 20:03:55 - Forum: Astra-J/GTC
- Replies (1)
Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
[attachment=1235]
[attachment=1236]
| Brake lights |
Posted by: GILSLEY87 - 3:rd-Jan-2021, 13:41:36 - Forum: Electrical
- Replies (7)
Hellow sorry if I have posted twice I have a astra j 2011, long story short I went through a puddle and had to change my electric parking brake motor changed this and works fine, the problem I now have is my brake lights won't go off even when I switch the car off they only turn off when the battery is disconnected, then when re connected they come back on, I have tried taking the fuse and numerous relays out still doesn't go off I have tried unplugging both cables going to brakes still doesn't go off I have even checked under the fuses it's dry and no moister please help thanks in advance
| Car won’t start when cold |
Posted by: Needanalias - 2:nd-Jan-2021, 23:24:35 - Forum: Astra-J/GTC Technical
- Replies (8)
Hi, I’m new to the forum, never really had to ask for help as everything’s on here but I have a problem I can’t find an answer to. I have a 2010 2.0D Astra J that won’t start when it’s cold. Initially I thought it was the battery and have replaced that. I then changed the glow relay and plugs and I’m still having trouble when it’s cold. It will start with easy start (I know I shouldn’t use it in a diesel) but after using that it will continue starting all day until the engine gets cold again. I took it to a mechanic before doing the plugs and he said fuel is getting to the engine and he was 100% the plugs needed changing. I did check them with a multimeter and they were fine but replaced them anyway. Any ideas?
