| Welcome, Guest |
| Forum Statistics |
» Members: 12,319
» Latest member: Pajda223
» Forum threads: 4,568
» Forum posts: 49,721
| Latest Threads |
From $50 to $5,700: The B...
Forum: Vauxhall General
Last Post: Jonathaneuk
20:th-Feb-2026, 04:07:48
» Replies: 5
Binance Mining Paid Me $9...
Last Post: conyas92
19:th-Feb-2026, 19:25:28
» Replies: 5
| Advice please! |
Posted by: KierranBond - 26:th-Jan-2017, 17:55:33 - Forum: Astra-J/GTC
- Replies (7)
Afternoon!
This is my first post. I bought myself a 2013 2.0 CDTI Elite on Monday. Loving it so far, having some right fun driving it.
Just after a bit of advice really. Is there anything I need to know, anything I should be looking out for or just some general tips?
Cheers!
| New posts |
Posted by: Big Dave2 - 26:th-Jan-2017, 12:06:40 - Forum: Site help
- Replies (5)
After using the "new posts" button to see what new posts there are in this forum, how do I make them all read? I can't find a button to do so. Thanks.
| hello |
Posted by: mark tourino - 25:th-Jan-2017, 22:35:13 - Forum: Introduction Area
- Replies (1)
I am interested in mechanical & electrical elements of all Vauxhalls, I do have global tis & tech 2 device which I have modified my Corsa D 1.3 however I just had to replace & reprogrammed my new ECU & I previously replaced my IPC about a year ago, however I can't seem to get my car to start & I was wondering if it had anything to do with the replacement IPC immobiliser which wasn't programmed to the original ecu & tech 2 is showing as security code status not entered
Any solutions
Regards
Mark
| Cascada led indicators |
Posted by: Wayneofwolves - 24:th-Jan-2017, 19:12:34 - Forum: Astra-J/GTC
- Replies (15)
Hi anybody tried fitting these EBay item number 371098650242 being as The Cascada uses the same wings was wondering if they would fit without modification
Wayne
| RDX Design |
Posted by: Wayneofwolves - 23:rd-Jan-2017, 20:44:26 - Forum: Astra-J/GTC
- Replies (6)
Hi all first post so be gentle
Anybody fitted the rear bumper lower valance
And if so what's the quality like
Regards wayne
| Updated version of Navi 950 IntelliLink |
Posted by: Greg-new - 22:nd-Jan-2017, 14:59:35 - Forum: ICE
- Replies (4)
Hello,
I just bought a used 2015 Zafira with Navi 950 IntelliLink. The seller claimed that he updated it recently, but after I used it for a bit, I think he never updated it. Does anyone know what's the most up to date version of the Navi 950 IntelliLink system?
Thanks for all the help.
| Faulty Boot Seams? |
Posted by: ben. - 22:nd-Jan-2017, 13:00:05 - Forum: Astra-J/GTC Common Problems
- Replies (2)
Good Morning (Just!)
I recall reading somewhere that early Astra's have a problem with the boot seams failing but I can't locate it.
Reason for asking is my Astra has water in the footwell which was partly due to the high level brake light, which is now changed.
However I am still getting water in the boot after rain and it appears to be coming out the seam on the boot floor at the back. I suspect this as when I wiped the water away I could see a drop of water re-emerging through the seam.
So I've got myself some potential options;
1. I'm trying a penetrating leak and crack finder which should cure it.
2. Get some seam sealer and clean the outside behind the bumper and cover the affected areas.
3. As I have only had the car 9 days I send it back to the dealership for them to sort?
Car is 2011 2.0l CDTi SE
Thanks,
Ben.
| GTC 1.6T Help |
Posted by: JJ00 - 21:st-Jan-2017, 16:04:16 - Forum: Astra-J/GTC
- Replies (6)
There is a k&n typhoon air intake kit for the 1.4 gtc but i can't seem to find one for the 1.6
will the 1.4 kit fit on the 1.6?
| slow to idle hanging revs |
Posted by: custardsastra - 21:st-Jan-2017, 03:03:21 - Forum: Astra-J/GTC Common Problems
- No Replies
hi all question for you all has anyone had an issue with the revs hanging around 1200 -1500 rpm then slowly dropping to idle on 2.0 cdti sri
everything else seems ok i only have a code reader which i shall be putting on tomorrow to see if anything pops up but at a wild guess im thinking throttle body gunked up causing it to stiffen up
i only had the car 3 months it has 60k on the clock says full service history but as i havent done this myself its just a piece of paper and i doubt very much the egr system has ever been cleaned
thanks for any help
