boot seams? faulty
Faulty Boot Seams?
Good Morning (Just!)
I recall reading somewhere that early Astra's have a problem with the boot seams failing but I can't locate it.
Reason for asking is my Astra has water in the footwell which was partly due to the high level brake light, which is now changed.
However I am still getting water in the boot after rain and it appears to be coming out the seam on the boot floor at the back. I suspect this as when I wiped the water away I could see a drop of water re-emerging through the seam.
So I've got myself some potential options;
1. I'm trying a penetrating leak and crack finder which should cure it.
2. Get some seam sealer and clean the outside behind the bumper and cover the affected areas.
3. As I have only had the car 9 days I send it back to the dealership for them to sort?
Car is 2011 2.0l CDTi SE
Thanks,
Ben.
Yes there was a seem issue on early models.
If you've only had it 9 days I would get the dealership to fix it.
Just to close this out, I smeared some silicon sealant over the seem and its been fine so far.
  Water leak in boot, spare wheel karl100100 12 18,829 27:th-Jan-2021, 12:49:34
  Car boot. Spud7997 9 9,773 1:st-Feb-2019, 12:31:26
Last Post: Youngy93
  Water ingress in boot Woodsy 10 21,511 7:th-Mar-2017, 08:32:22
Last Post: Tonsor
  Boot noise?? Anyone help me?? LukeAstra15 4 8,299 16:th-Feb-2016, 21:38:45
Last Post: bhalay207
