0)
Threads: 1
Thanks Received:
0 in 0 posts
Car: Astra 1.4T Sri (62)
Sex: Undisclosed
Hi everyone.
For 2 1/2 years I've had water entering into the car through the interior trim of the tailgate. Not sure how this is getting in but it's evident after it has rained heavily.
The water seems to gather inside the tailgate structure and then enters the car through both of the two pop out plastic grey covers behind the tailgate lights. It's also come through the tailgate locking mechanism. The three drain holes are clear.
I notice it when the tailgate is opened fully and then the water drips out at varying rates.
It has now been into VX 15 times and had rear lights sealed, rear window re sealed etc etc and finally a brand new tailgate but the problem is unbelievably still there. Car is now out of warranty but its going in again next week - but I don't hold out much hope to be honest!
Has anyone come across this problem before or know how to rectify it once and for all? It's driving me NUTS after all this time.
I have pictures but cannot figure out how to post them.
4)
Thanks Received:
4 in 4 posts
I'd get them to check the welded seams and also the gully that is covered with trim where the roof rack goes.
2)
Thanks Received:
0 in 0 posts
14
have they changed the tailgate brake light the seals can go on them
also remove the black plastic cover at the top of the tail gate
and check the plastic caps are there
2)
Thanks Received:
0 in 0 posts
14
Go to elesmereport as they are better than Birkenhead for sure if you are going to lookers
0)
Threads: 1
Thanks Received:
0 in 0 posts
Car: 2015 Vauxhall GTC SRI 2.0 CDTI S/S
I Have water ingress in my boot (15 plate GTC) and terrible issues with freezing up on the inside
Ive been inside the boot today with the jet wash being blasted all around the seals, lights, windows of the rear of the car. Not a drip from anywhere
With the looks of the soaked (and smelly) boot floor - Water seems to be getting in behind the number plate. There is some plastic trim with sound deadening behind which is damp also. i can feel some vents behind the plastic trim which are all wet too
Does anyone know how to remove all this trim? Id like to have a look at these vents to see
Thank you
4)
Thanks Received:
4 in 4 posts
Pull the bottom out abit then pull the top up. pull the rubber off as it makes the job easier.
0)
Threads: 2
Thanks Received:
0 in 0 posts
Car: Astra J 1.6 VVT
I had this very same problem but found the where it's coming from. If you open the boot and look on car bitself where the boot hinges are there are 2 caps. One left and one on the right. The water was coming in through those for me. I found this out due to where the roof liner meets the boot it had came away and opening this a little more I could see new and old water marks directly under those caps at either side. Mine is going in tomorrow morning to get sorted. I'll add pictures shortly. Hopefully this will help others with the same problem.
