» Members: 12,338
» Latest member: Griff81
» Forum threads: 4,563
» Forum posts: 49,693
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
  Insignia vx flat steering wheel
Posted by: Anthonwr - 20:th-Aug-2021, 20:25:29 - Forum: Retrofit Research - Replies (1)
Quick question
Does a insignia vx line  flat steering wheel for the Astra GTC ?
  Genuine GM MDI
Posted by: livo - 20:th-Aug-2021, 18:14:57 - Forum: What's it worth - No Replies
Thinking of selling my genuine gm mdi I got it to program my navi950 but ended up send it to Jpbroad1970 for him to do it so I no longer need it, not sure what would be an expectable price for it, it comes with power supply, usb cable, network cable and wifi card.
https://photos.app.goo.gl/26AatwwXB8B17XpH8
  Paid subscription
Posted by: livo - 20:th-Aug-2021, 09:24:34 - Forum: General Chat - Replies (2)
Hi, can anyone tell me if you still get access to downloadable how to's and to post items for sale with the £5 subscription, I paid the subscription on the 13th but have no access to these parts of the forum. Thanks
  Induction kit
Posted by: carlosfootball - 19:th-Aug-2021, 16:45:57 - Forum: Astra-J/GTC - No Replies
New member here, First post!
So why is it that the only induction kits I can find is a K&N Typhoon (£300!) and some Badass one (£200 but never heard of them so dubious)?
Is it due to needing to have somewhere to put the sensor?
What are your guys opinions on the Typhoon?
I have a 2012 Astra J 1.4T Sri VX line
Regards
  Lowering springs identify front rear
Posted by: martinpe68 - 15:th-Aug-2021, 15:15:44 - Forum: Astra-J/GTC - Replies (1)
COBRA lowering springs 30/30 mm for Astra Sri GTC 2012 2.0 CDTI
Which are front and which are rear?
The long springs have VA stamped on them and shorter springs have HA stamped on.
Which way up do they go? Is the writing always reading in the normal direction or it can soemtimes be upside down?
  2.0 CDTi Auto Gearbox Oil Change
Posted by: Dennis S - 13:th-Aug-2021, 14:29:25 - Forum: Astra-J/GTC - No Replies
Just a quick note to say that last week I had my auto transmission oil changed on my 2.0 CDTi Astra at 90,000 miles. I've had the car 5 years.
Although the car was driving ok with no real problems I had wondered if a transmission oil change would improve it.
Got the transmission oil changed at the local Vauxhall dealers, cost me just over £80.
Noticed an immediate improvement in the way the car drives. It changes up quicker, holds onto a higher gear for longer before changing down. Feels like it's making better use of the engine's torque. Smoother altogether, should have got it done years ago.
Would recommend it to anyone who might be considering getting it done.
  navi950 programming
Posted by: livo - 13:th-Aug-2021, 11:01:37 - Forum: Retrofit Research - Replies (2)
Hi, Can anyone tell me if I can use normal programming via sps or if I need a vci code to reprogram a navi950 from Mokka controls to Astra controls? & can I add review camera and dab+ to it via normal programming or does this also need a vci code? I was hoping to send it to Rusty for this to be done but he is a busy man and i am wanting to get this done asap. I have a genuine Mdi to do the programming & once done I will no longer need it so can pass it on for a very reasonable cost to anyone who is willing to help me out with info on the programming. Thanks
  DPF problems almost new
Posted by: Caddylac - 11:th-Aug-2021, 21:52:46 - Forum: Vauxhall General - Replies (3)
Hello all, recently I got some error messages on my 1.3 Astra but before I go to a specialist I would like to see if is something that I can do by myself
So, a couple of days ago I got "Service Vehicle Soon" message before starting the engine. I kinda think that the problem might be related with the DPF since in the last 3 weeks I've used the car only for a couple of miles to reach my work place. I've moved very close to work but since I don't have a parking permit yet, I need to move my car from the place I live during the day
Yesterday I had to do some work 100 miles away from work and I decided to get my car in order to clean the DPF, after 20 miles I got the message, "DPF Cleaning, Continue Driving", after another 20/30 miles the message change to "DPF is Full, Continued Driving Mandatory. I was on the highway, so I continued for another 60 miles until I've reach my destination but nothing, the message didn't go away. On my way back, same thing, 100 miles but no cleaning. The message comes on as soon I turn on the keys, also "Service Vehicle Soon"
The filter is brand new, only 3000 miles made so far...
Arrived home, I've connected the computer and I got this error messages:
P2458-57 Diesel Particulate Filter (DPF)  Regeneration Time - <Unknown status byte>
P2453-56 Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit - Too Many Transitions
P0192-5A Fuel Rail Pressure Sensor Circuit Low Voltage - Not Plausible
Is there anything I can do by myself before hearing an expert?
Thanks in advance for any advice!
  Flywheel or release bearing
Posted by: Dvaltd - 11:th-Aug-2021, 10:33:44 - Forum: Astra-J/GTC Technical - Replies (2)
Just bought a 1.7 cdti with 125000 and noticed that when on idle it’s noisy and car vibrates but when i press clutch it stops also gear lever is jumping when in 1,3,5,6 gear but 2,4 are fine also wine in all gears so rebuild/new gearbox,im going to change myself just don’t know if to buy a new clutch/flywheel as the clutch feels perfect just under half pulling away [Image: cdbd1b21a8aa2441f9c4062cad2c91fc.jpg]
[Image: 013fd44ecf1321b556b88b0e258a475d.jpg]
Not bad for £1250 with full history and long mot
Question Three GTC VXR questions
Posted by: neilll - 10:th-Aug-2021, 16:44:13 - Forum: Astra-J/GTC - Replies (3)
Thinking of getting a VXR for a few years before we all end up driving Milk Floats
1. Looking for one in Arden Blue, why are they so scarce?
2. What's the average MPG for a VXR (without any silliness chasing BMw's) ? :-)
3. Are all VRX full leather interior or are some part leather?
