bumper inlay rear
Rear bumper inlay
Can anyone check the part numbers for the rear bumper insert with the exhaust cut out.
I'm wanting part number for facelift and preface lift
Wanting to find out if a pre facelift will fit the facelift
I think they are the same mate will check tomorrow.
No mate they will not be the same part number they are a bit different also will they fit each other most likely
Looking on EPC they look the same bar the cutout.
Will have to try it and see. I see no reason why it wont though fit.
there is a lip on the new one the old one does not have the lip
Not a massive difference then. Think this is so I can fit the exhaust tip. Will see how it looks at Trax. If not will have to cut mine.
It's quite easy to cut mate I've cut mine
It's getting the measurements right measure 3 times cut once.
  Lowering springs identify front rear martinpe68 1 3,921 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 14,543 6:th-Jun-2021, 18:25:04
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,893 24:th-Jan-2021, 14:44:22
  VXR Front Bumper onto a 5dr Bear 2 6,252 3:rd-Oct-2020, 11:48:59
  Rear diffuser Elad1962 3 5,061 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,672 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,870 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 6,744 28:th-May-2019, 10:53:57
  VX Line / Ltd Edition Bumper Wanted crosser74 1 5,199 29:th-Jan-2019, 08:05:23
  electric rear windows marky79 5 7,172 11:th-Jan-2019, 09:04:32
