kw a it 6 please 132 direct turbo is advise engine z16let port? 1 or indirect
Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port?
Hello guys,
searching a lot I was not able to find if the Z16LET - 1.6 turbo, 132 kW petrol engine is a direct or an indirect port engine. I suppose that this 180 HP engine that was used in the 2nd gen of Astras H an then in Astras J is an indirect port petrol engine. And I suppose the 200 HP 1.6 turbo petrol engine that came later is already a direct port engine. Can anyone please confirm or specify this? Thank you.
(13:th-Apr-2021, 09:21:23)UseThe4s Wrote: Hello guys,
Hello the engine you are talking about is with multi-point indirect injection. This is the old gen 1.6 turbo engines. The new one putted in J facelift(2013-2015) is called 1.6 turbo SIDI(A16 XHT) with 170 hp and direct injection. The same engine later putted into K with 200 hp is again 1.6 turbo SIDI(A16 SHT) technology, but I believe kinda remapped, no bigger turbo. Also the engine you are talking about(Z16LET) has problem with the 4th cylinder, they tend to crack the cylinder head so I would avoid it. This same engine is also putted in 1st gen Corsa OPC/VXR there is 192 hp and most of the owners have problems with it. Sorry for my English. I hope I helped.
(17:th-Apr-2021, 17:20:59)foxydimsi Wrote: Hello the engine you are talking about is with multi-point indirect injection. This is the old gen 1.6 turbo engines. The new one putted in J facelift(2013-2015) is called 1.6 turbo SIDI(A16 XHT) with 170 hp and direct injection. The same engine later putted into K with 200 hp is again 1.6 turbo SIDI(A16 SHT) technology, but I believe kinda remapped, no bigger turbo. Also the engine you are talking about(Z16LET) has problem with the 4th cylinder, they tend to crack the cylinder head so I would avoid it. This same engine is also putted in 1st gen Corsa OPC/VXR there is 192 hp and most of the owners have problems with it. Sorry for my English. I hope I helped.
Hello, thank you for your your answer. Well, I do have a 2014 Astra GTC with exactly this engine so not sure about the 2013-2015 facelift you are writing about, maybe it was one of the last pieces with this engine. Anyway, I am pretty glad to have this indirect injection engine, as I am aware the direct injection engines tend to suffer from intake valve carbonisation more. Hopefully if the engine has a good care and is not put a lot of stress on it then it should last I guess and not suffer from the 4th cylinder problem.
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,541 12:th-Sep-2021, 15:24:05
  1.4T Engine noise Nathan191210 1 1,317 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Turbo failure common? Euroshopper 2 2,460 24:th-Nov-2020, 08:35:48
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 39,222 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  1.6 cdti engine reliability Loddy Jeff 7 8,852 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
Spanner Light illuminated with engine off Wwood1991 2 3,245 11:th-Feb-2020, 13:01:57
  New Engine Needed ? Breengin 19 7,627 14:th-Mar-2019, 08:48:57
  Squeek/Rattle when starting engine Wabe_IV 4 3,462 7:th-Feb-2019, 12:15:33
  Noise when turning engine off Marc_81 6 4,755 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
  Engine Oil. THOMAS123 2 2,948 7:th-Oct-2018, 21:43:14
Last Post: THOMAS123
