needs priming? fuel pump
Fuel pump needs priming?
I recently had my fuel tank replaced due to a hole in the pipe s, since it’s been replaced I need to prime my fuel pump every time I start the car or it will just turn over for what seems like ages!
Is there any way of fixing this??
Should be self priming, I'd check fuel filter condition also. When I did my fuel filter I'd took a few turns before springing into life.
I also had to have a new fuel tank as had a hole, I have an issue now though of tank not registering level correctly. I may have a look in the summer but I tend to fill up on halfway. You could also check they haven't kinked a pipe.
I had a new filter fitted also, it starts fine with stop/start just when it’s been stood for a while I have to turn the key and wait for pump to prime before I start it
Sounds to me like the fuel is bleeding back to the tank, don't know if they have one way valve or not but the pipe should remain full
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 1,514 30:th-Dec-2022, 17:32:20
Astra 1.7 CDTI fuel quality problem klajdi 0 2,038 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 2,637 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 1,728 12:th-Aug-2020, 07:58:08
  1.7cdti drinking fuel Hazard10 2 3,033 9:th-Jan-2020, 22:13:15
Last Post: Peckalz
  New Fuel filter. Wont start SALMHAGE 1 2,403 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  How to change Astra j fuel flap mechanism? Amazingusername 2 2,558 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
  Fuel consumption - 1.3 CDTI mw2299 3 3,686 19:th-Oct-2017, 10:53:43
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 13,501 23:rd-May-2017, 07:00:23
  Fuel Gauge Indicator Farrael 7 6,511 10:th-Aug-2016, 10:01:31
Last Post: bhalay207
