common? failure turbo
Turbo failure common?
Hello,
I had my car at service and they told me I had to change my turbo. Is this a common problem?
The fault codes was P0299 and P003A.
Is there any knows issues with the turbo on this car? It has only gone 75000 km / 46000 miles
Opel astra J, 2010, 1.3 CDTI.
Kind regards
I've had to do mine on 2.0 cdti
Turbo is not common the waste gate is however.
Also the turbo boost control solenoid valve is very common on these and can cause P0299 error if you do change it do not buy used.
The P003A means the turbo veins need to be learned..
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,730 12:th-Sep-2021, 15:24:05
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 2,656 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  !.4 Turbo remap Midlands simsgtc 5 4,120 15:th-Jul-2018, 21:51:29
Last Post: simsgtc
  Astra 1.6 Turbo Engine light P0171 abba34 1 4,997 7:th-Aug-2017, 04:21:09
Last Post: sanj424
  Turbo charging a non-turbo 1.6 Elite Ceepee 10 8,304 27:th-Apr-2016, 18:50:32
Last Post: Ceepee
  Turbo Noise Jamiemccallum_ 3 4,169 2:nd-Mar-2016, 18:35:37
  Induction Kit for 1.6 Turbo Tjs1ngh 11 8,727 6:th-Oct-2015, 22:01:56
Last Post: amjgtc
  A17DTH turbo flutter Jj0063 16 10,186 22:nd-Aug-2015, 19:29:54
  Finally picked up my astra 1.4 turbo limited edition Jon3166 14 9,485 23:rd-Nov-2014, 15:29:37
  Maff sensor housing for 1.6 turbo SI SRI 7 6,155 18:th-Oct-2014, 01:13:55
Dominattor (4:th-Sep-2023, 01:02:22), avenue17 (31:st-Jan-2024, 08:04:32)
