6 turbo housing sensor 1 for maff
Maff sensor housing for 1.6 turbo
Anyone know where I can get the maff sensor housing so I can attach my induction kit?
i think the 2.0 cdti and 1.7 cdti are not attached to the air box
but even second hand there not cheep but you would only need the housing not the sensor as you have that already so get the part number and price for the housing hose only it may be Cheeper
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...19f16d85c7.
Cheers mate I will have a look and see how much they are priced at. I'm guessing that the connections are all the same on all astra engine or am I just hoping that so it will be easier?
any news si have you found one yet
No none around at the mo so bought panel filter for now and ordered blue hosing to add to airbox.
Does the turbo have a resonator on the air intake before the air box if so best to remove for better air flow and indiction sound from a k @n panel filter
I'm going to have to have a look. I think it does though.
just doing the removal now if you have it as i know this is on the petrol's but not shore if this is on the on the turbo
http://www.vxoc.org.uk/forum/Thread-resonator-removal
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,629 12:th-Sep-2021, 15:24:05
  Brake pedal sensor learn. Richiew1986 0 3,007 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 8,341 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  parking sensor Qaranc 1 3,869 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,102 2:nd-Feb-2021, 21:12:47
  Turbo failure common? Euroshopper 2 5,207 24:th-Nov-2020, 08:35:48
  Glowplugs with pressure sensor or not Euroshopper 3 5,727 2:nd-Nov-2020, 16:01:21
  GTC Thermostat and housing Eve26 0 3,328 22:nd-Nov-2019, 20:07:23
Last Post: Eve26
  DPF pressure sensor richardhmorgan1 3 7,001 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  !.4 Turbo remap Midlands simsgtc 5 7,351 15:th-Jul-2018, 21:51:29
Last Post: simsgtc
