power steering failure whilst driving
hi guys, hoping you can help me with this one, I have a 2012 Astra j 2.0 cdti sri, I had a major service done on it last week, a week later on my way to work my power steering failed and it's telling me it needs a service, I was lucky I was on the straight part of the country road I was going down! Anyway once I got to work I turned car off for five minutes and it started working again, few days later and it stopped again as I was going down a38, any ideas what may be the cause? Anyone had this
Opel Astra J 1.6 A16XER fuel pump & canister failure
Did any body face problem in the fuel pump or canister before???
Failure Code 597, temp only 75 C
Hello
Astra J 2010 1.6 has servivce light on. Can be reseted by Menu button but comes back after 10 minutes. Code reader gives code 597 - related obviously to thermostat. Engine temp does not come higher than 75C, normally about 90C.  Both upper and lower cooler hoses are warm but not hot. Heater and ac works normally (blowing warm air). Runs smoothly all seems to be OK. Please help whether this is typical failure and where to start to fix it. Does this engine have electrical controlled/heate
TURBO FAILURE, something else wrong
I'm in rather desperate need of ideas! Just before Xmas on a 45-mile return trip, I started to hear the turbo. It wasn't loud, but clearly there unlike normal. At Xmas, we set of on a journey with our fingers crossed, but about 35 miles down the M74, going up an uphill stretch, the turbo gave up completely. We struggled on a bit further, but were soon leaving a smoke trail, and pulled off to get recovered. The car's been in getting the turbo replaced, but the garage doing the work (they're recom
Auxiliary Belt failure - cam belt change question
Hi all, I bought an Astra 2.0 CDTI recently and they fitted a new cambelt and waterpump as part of the sale. Just 2 weeks after getting the car the auxiliary belt shredded and snapped on the M11 and subsequently the brakes, power steering and just about every other light came on on the dash before the battery lost charge and it died. The garage I bought it from took the car back and put a new aux belt and battery in under warranty. They said the reason the belt snapped was due to a lose pulley b
Turbo failure common?
Hello,
I had my car at service and they told me I had to change my turbo. Is this a common problem?
The fault codes was P0299 and P003A.
Is there any knows issues with the turbo on this car? It has only gone 75000 km / 46000 miles
Opel astra J, 2010, 1.3 CDTI.
Kind regards
Has my Astra-J got a selective bulb failure warning system?
My Astra-J is a 2013 (63 plate) Elite model.
It seems very selective on telling me what bulbs have failed.
It has previously let me know I had a failed number plate light, DRL, dipped beam, and a brake light (no, not all at the same time )
However, it didn't inform me that I had a failed tail light bulb (one of the two pairs in the hatch), or more recently a high beam bulb.
Yes, I know you can't beat visually checking for yourself, but the bulb failure system on my old Vectra-C Elite was a
