steering wheel k astra from
Steering wheel from Astra K
Hello, guys. Does someone knows or have made this type of change to his car. Steering wheel from Astra K and to put it in J model.
I changed my standard steering wheel on my Astra K model for an Insignia Flat bottomed steering wheel fortunately all the steering wheel controls plugs were exactly the same configuration for both cars so I did the reverse procedures, the wiring & the airbag connector were ok on mine but there were two connectors on the Insignia airbag & a single connector on the Astra airbag, I wouldn't know what the airbag connector is on the Astra J but there is a tutorial on this site on how to remove the steering wheel & airbag, hopefully a straight forward swap.
Depends which wheel you are thinking of installing.
if the buttons look like this https://www.ebay.co.uk/itm/2016-VAUXHALL...SwRxBfa1-f
Then you would need to modify the resistor ladder as its the wrong way round.
I'm not sure in terms of fitment though if it fits or not.
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,532 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,052 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Steering wheel angle, esp, power Steering smoky-jr 3 2,596 6:th-Jun-2021, 18:23:26
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,565 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,798 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,891 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,027 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,155 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,479 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,810 24:th-Jan-2021, 14:44:22
milozic (12:th-Jul-2023, 11:19:41)
