Dbilas Flowmaster or just K&N panel filter in standard airbox?
as above...has anyone actually had a car on the rolling road to see if there is any benefit to having a Flowmaster? and to see if the standard air box is better with a K&N panel filter??
Astra-K video
Just found a video on you-tube
[Video: https://www.youtube.com/watch?v=rmqHUcmc7lw]
Air filter K&N
So my air filter arrived today, I took my factory one out and tried to fit the new one... For some reason the new one is more rectangular than the factory one which is totally square... So it wouldn't fit! Have they sent me the wrong one?
Ta
Pipercross or K&N????
I want to change the standard filter to either a pipercross or K&N panel filter. Has anyone used either and can recomend one of them? Is there any difference apart from price? Pipercross about £10 cheaper.
Pipercross VS K&N panel filter (Astra GTC 1.6T)
Hey guys!
Recently picked up a 2013 GTC (1.6 Turbo 180ps) and I am currently looking into smaller tuning options, at least for now anyways.
After looking at cone filters, I've pretty much ruled them out due to the limited amount of kits out there, the price of the kits available, the effort of making one myself and heatsoak issues.
So back to the question, as far as I know the Pipercross is about £15 cheaper and is a dry filter, vs the K&N which I believe is oiled.
So all I really
Partnumber - Astra K
hello,
i know this is an Astra J forum, but have left the J for an K,, and i wounder if some one can check this partnumber before i order..
Part number 13432224
it should be an switch with 6 buttons located with the gear shalter.
Astra J to an Astra K
Hey guys quick one. does anyone know what year the astra K came into affect. My friend has a vauxhall astra 62 plate but not sure if it's a J or K but I can't get.him to send me any pictures as he is away.
Any help appreciated.
K&n air filter
Dose fitting a k&n air filter make any difference
2016 Astra K GTC Malfunction Light Question
Hi Everyone
I could do with some advice to help with an issue that has just surfaced.
I started my Petrol GTC this morning (27/10/2018). The warning lights came on as normal and then all went our except for the Yellow Engine Warning Light. This light stayed on. The car seems fine to drive. It has done 13,010 miles, had a full service 4 months ago and has been sitting in the drive for the last 3 weeks doing nothing while I recover from an operation. The oil level is fine. I have checked and
astra k cluster on astra j
In the last two days, i was wondering if its any solution to retrofit the cluster and the steering wheel from astra k.
In the picture the cluster connection its the same..but it will work ?
