gauge engine and shaking temperature
Temperature gauge and engine shaking
the problem is with my car but the temperature gauge is fully maxed out so am guessing there’s something over heating but just what and when I turn the engine on it doesn’t start sometimes and when it does the the engine starts shaking any chance you know what the problem is Would hugely appreciate it
It could be anything.
could be a thermostat, water pump, coil pack (if petrol) head gasket the list goes on be far better getting to a garage & let them go check out.
(19:th-Aug-2020, 07:30:28)Rusty2009 Wrote: It could be anything.
Yeh just got it checked out the engine and radiator sensor are showing different readings making the temperature gauge show red and the engine shaking was a mistake it was just the fan turning on cause it thinks it’s over heating
Yeh just got it checked out it’s the engine and radiator sensors not showing the same readings making the car’s temperature to show red and was wrong with the engine shaking it’s just the fan Turning on due to it thinking it’s over heating but it’s not
  Exhaust Gas Temperature Sensor P2084 bagnallman 4 13,127 2:nd-Sep-2021, 08:17:51
Last Post: geoffsnook
  Where to find the engine code? everson38 6 9,846 12:th-Aug-2021, 14:34:48
Last Post: Dvaltd
  Exhaust Gas Temperature too high bank 1 everson38 1 5,631 18:th-Feb-2020, 08:20:42
  Engine Oil grade / spec / amount everson38 10 13,262 27:th-Sep-2018, 00:37:16
Last Post: everson38
  1.6 CDTI engine problems ? Loddy Jeff 1 10,214 17:th-Aug-2017, 08:36:49
Last Post: Jerry
