Threads: 1
Car: 1.7CDTI
Firstly hi Everyone
new to this forum so hopeful be able to get some help form you guys as heard some good things...
I have a 2014 Astra J 1.7 Diesel that's just failed its MOT due to wipers not providing water.
both front and back decided to stop so did the usual, blew some air through the pipes and cleaned the nozzles and washer bottle out
wasn't getting a hum from the motor when the stalk was pulled forward or backwards so purchased a new washer pump which solved the rear issue but the front still wasn't working so bought a new stalk from Vauxhall fitted that and no change.
when you push backwards everything works as it should, when you pull forward the wipers sweep as normal but no motor sound or water.
its not the pipes as i swapped round the fittings so pressing backwards sprayed the front and everything was OK
however doesn't seem to want to engage the motor when pulled forward
anyone got any ideas, it doesn't come up with any errors that i can see so very puzzled, have i missed something simple or is this a modual or earthing issue and can it be solved easily.
got a free re-test in 7 days so limited time to fix and this is all it failed on so any help would be much appreciated
over to you guys and girls
Thanks Received: 4 in 4 posts
Hi & welcome,
Ok firstly check fuse 40 10A in the engine bay.
Failing that there is a relay KR11 which is non serviceable and means a replacement fuse-board.
Make sure some-one is stood by the fuse board and test if they hear a click the relay is working.
Threads: 1
Car: 1.7CDTI
(14:th-Aug-2020, 19:00:38)Rusty2009 Wrote: Hi & welcome,
cheers Rusty2009
Bugga, hoping it wasn't something like that, fuse 40 is OK
checked all the fusses and there all OK
any idea how easy is it to replace the fuse board and are they ridiculously expensive ??
Fuse-board is easy.
Whats your reg I'll get you the number can pick them up quite cheap on ebay.
Threads: 1
Car: 1.7CDTI
15:th-Aug-2020, 12:00:14
(This post was last modified: 15:th-Aug-2020, 14:07:56 by Rusty2009.)
Hi reg is Removed by admin..
Anyone got a how to to replace the fuse board
Cheers Ron
Scratch that box is out, very easy job. Just need to source a replacement and hopefully get it all done before wednesday for re-test
Threads: 1
Car: 1.7CDTI
Cheers for the Info, will grab one and see if it sorts the issue.
Threads: 1
Car: 1.7CDTI
Hi ,fitted the fuse board this morning and now car wont start and comes up with service EBC and service Power Steering .
Wipers work fine thou..Haaahahh
Does the fuse board need coding to the car, and if so can this be done from standard diagnostics or do I need to ge Vaux-Com.
Cheers Ron
21:st-Aug-2020, 07:15:09
(This post was last modified: 21:st-Aug-2020, 07:16:27 by Rusty2009.)
Make sure all the 3 nuts are done up tight these pull the connection blocks underneath up tight to the board if they are done properly you will get errors.
No fuse-board on the Astra-J needs coding to car & don't let anyone tell you otherwise (I've swapped out that many boards on retrofits to know).
