release j navi950 maps end of astra
Navi950 maps end of release Astra J
Sent a mail to opelnavigation.com and asked for new release of roadmaps 2020 for intellink 950 Astra J.No more releases for 950 system.2018 is the latest.
If you compare it to the 900 system that has SD card there will be releases 2019/2020 maps Astra J.
Does anyone have any ideas about how to get never roadmaps,mine is the 2018 maps USB.
No the newer maps won't work.
Vauxhall told Here to stop making maps for the 650/950.
The 2018 maps aren't even 2018 they are 2016 and missing loads even places which have been around for 20+ years.
I've given up with the Navi now I use WAZE streaming via BT.
I'm looking into finding an android auto double din with 6.5-7" detachable screen so I can move the screen up to the top and have WAZE on the screen rather than the phone.
Thanks Rusty...
Hmmm,so why continue with the older system navi 900 and produce maps but SD card.What is so special with the 650/950 system..
No idea you try & get vauxhall to answer the question they refuse and blame it on HERE.
HERE will only say they've been told by Vauxhall not to make any more updates.
Does make you wonder how they are getting away with it as they are meant to support built in navigation systems for a set amount of years after production stops.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,731 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,641 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,111 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 9,020 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,950 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,538 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,388 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,481 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,160 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,160 24:th-Jan-2021, 14:44:22
