Remote boot popping on a meriva (non canbus boot release i believe)
I want to make my boot open remotely when i am approaching it with bags of shopping in my hands... the car is a 2011 meriva B....
Going to try the springs on the struts, my struts are pretty weak so time for new ones, so also going to get uprated pressure struts... actually gonna get adjustable pressure struts... they start with 70 newtons of lifting power... and a bolt can be opened to release some of the nitrogen pressure if they are too powerful to close the boot lid)
This is with the
W072 (M072 Successor) Pre-Release Information
Hi All!
Right, bit of an "exclusive" here! I've been in close contact with Rob from IceBox Auto for the past year or so and he's just informed me that the successor to the M072, the W072 based on the S200 architecuture rather than the S160 architecture that the M072 is based on, is due for release in the next few weeks!
This unit will have a better display, more storage, Android Oreo etc.
Below is all of the current info that Rob has been able to provide to me:
https://drive.google.c
Release gear knob reverse lockout bar
How do you release the reverse lockout bar when taking the gear knob off??
i knot to press in and slide up the blue collar to release the knob from the shaft, but it's still held down due to the reverse lockout plastic bar,  i can't seem to se how to release it, and dont want to just pull incase i break it
Navi950 maps end of release Astra J
Sent a mail to opelnavigation.com and asked for new release of roadmaps 2020 for intellink 950 Astra J.No more releases for 950 system.2018 is the latest.
If you compare it to the 900 system that has SD card there will be releases 2019/2020 maps Astra J.
Does anyone have any ideas about how to get never roadmaps,mine is the 2018 maps USB.
Flywheel or release bearing
Just bought a 1.7 cdti with 125000 and noticed that when on idle it’s noisy and car vibrates but when i press clutch it stops also gear lever is jumping when in 1,3,5,6 gear but 2,4 are fine also wine in all gears so rebuild/new gearbox,im going to change myself just don’t know if to buy a new clutch/flywheel as the clutch feels perfect just under half pulling away [Image: https://uploads.tapatalk-cdn.com/2021081...2c91fc.jpg]
[IMG]https://uploads.tapatalk-cdn.com/2021
