drinking 7cdti fuel 1
1.7cdti drinking fuel
Hi guys I have a 1.7cdti ecoflex, occasionally rough idle, got told maybe injectors but the main question is I've spent £230 and only got 1000miles out of it, is that normal for a vauxhall? Could it be the injectors ?
I do drive mixed and mpg averages goes from 40-45mpg but surely this don't add up right.
Any advice/help would be appreciated
Sent from my GM1913 using Tapatalk
It could be anything there are so many things.
I've noticed on mine it seems to drink fuel (or so the gauge says) but when I fill it up it's not taking as much to fill.
To and from work I can average between 40 to 47mpg, on a long distances (200+miles) i can get up to 60mpg depending what speed i do.
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 1,573 30:th-Dec-2022, 17:32:20
  Fuel pump needs priming? Amazingusername 3 1,584 21:st-Mar-2021, 20:34:09
Astra 1.7 CDTI fuel quality problem klajdi 0 2,048 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 2,714 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 1,730 12:th-Aug-2020, 07:58:08
  New Fuel filter. Wont start SALMHAGE 1 2,412 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  How to change Astra j fuel flap mechanism? Amazingusername 2 2,568 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
  Fuel consumption - 1.3 CDTI mw2299 3 3,694 19:th-Oct-2017, 10:53:43
  The Famous 1.7CDTi 125horse Simon Templar 2 3,240 22:nd-Sep-2017, 23:36:08
Last Post: Simon Templar
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 13,516 23:rd-May-2017, 07:00:23
