radar sensor cabling
Radar Sensor Cabling
i buy one front radar sensor for my Insignia to implement it for AAC.
Part number of sensor module are 23438076. About cabling that i found is:
pin-1 - 12v Positive voltage - DRAW CURRENT - 900mA
pin-2 - GND Negative voltage
pin-5 - Circuit 6106 - White                   connected to pin-20-ABS
pin-6 - Circuit 6105 - BU/YE                  connected to pin-21-ABS
pin-7 - Circuit 2501 - WH - CAN L          connected to pin-6-ABS
pin-8 - Circuit 2500 - BU - CAN H          connected to pin-5-ABS
pin-10 - Circuit 5986 - WH/BU - IGN      connected to pin-33-ABS    -  +12DC / 3mA
The question is 12v Positive are is ALL time or switched?
Circuit 6106 is ??
Circuit 6105 is ??
Receptacle connector is 1488533-5 or 2203663-5. The first one is out of make.
I have a opel-eye in my car, have all needed buttons on steering wheel only this radar is missing and activation too Smile
I attach specification for this sensor but cabling are for Range Rover.
The second file are connector. For this sensor fit Option A Black with 2 Notches in two ends.
Regards
.pdf   radar sensor.pdf (Size: 321.25 KB / Downloads: 29)
.pdf   ENG_CD_2203663_A7.pdf (Size: 687.56 KB / Downloads: 25)
  Parking Sensor Display Vx-Mad-G 14 9,269 29:th-Mar-2018, 16:49:42
Last Post: zzattack
  Locate sensor voltage Rain cosmo black 2 3,957 9:th-Oct-2016, 15:02:44
Last Post: cosmo black
  Rain sensor Kado1111 70 31,629 9:th-Oct-2016, 00:32:21
  Front parking assist sensor SectorOMEGA 19 10,043 9:th-Jul-2016, 07:57:37
greg848484 (15:th-Jun-2023, 19:30:59)
