??? 45 17 of instead tyres 50 225
Tyres-225/45/17 instead of 225/50/17 ???
I need to change my tyres and thinking of whacking on some winters over the next few months.
Thing is, the 225/50/17 seems such an expensive size.
Can I change it to 225/45/17..?
If so, any impact to the car, drivability, stability, etc?
It's a 2011, 2.0 Diesel 5 door.
I would be more stable
But you would loose a bit of driving comfort and you would make astras already big space between tire and fender more bigger
Based on data from the web the original tyres are 215/50R17.
Small differences and like Jopo2311 mentioned impact on driving comfort.
Some numbers:
Circumference (2032 mm - 1993 mm)
Revs per mile (792 - 808)
Link: https://tinyurl.com/ycsnos9v
In our country it's allowed to use dimensions listed in homologation (type approval) card only.
I made a saving of around £15 a corner by simply just changing the speed rating from a 94V to a 94Y when I got new Bridgestone RE050A 250/50/17's recently.
Apparently a Y rating is more common, so it's cheaper than a V rated tyre.
You can go up in a speed rating, but not down from the recommended value.
personally, i would stick with a 50 profile, i had 45 profile on an Astra coupe and took it up to 50, far more comfortable on British pothole ridden roads.
Thanks guys, im going to stick with the 50's.
They are so flipping expensive. Anyone got a spare set, LOL!.
  Wobble after new tyres Craig2305 2 3,802 22:nd-Feb-2021, 09:17:25
  Roadstone Eurovis Sport 04 Tyres Vx-Mad-G 3 5,816 15:th-Mar-2019, 14:02:43
Last Post: Vx-Mad-G
  Winter/seasonal tyres? Exlabman 4 6,021 1:st-Feb-2019, 08:36:56
  Tyres Elad1962 1 3,992 14:th-Oct-2018, 22:51:46
Last Post: Jopo2311
  Tyres - what have you got on your car ? Dennis S 11 10,792 5:th-Aug-2018, 14:41:46
Last Post: mislav_os
  Which tyres should I have? Comments please....have a few choices Vx-Mad-G 28 23,230 7:th-Mar-2017, 06:50:45
Last Post: J1ODYA
  235/40 zr 19 tyres chrisb2511 5 8,719 1:st-Aug-2016, 18:55:16
Last Post: chrisb2511
  Accelera PHI tyres. bannan 6 9,289 7:th-Jun-2016, 22:14:51
Last Post: bannan
  Tyres Kris 34 28,583 15:th-Feb-2016, 20:47:33
Last Post: Kris
  Tyres for 18" Lewis6317 30 32,431 4:th-Jan-2015, 19:18:30
