gtc foglights astra retrofit
Astra gtc retrofit foglights
 Guys need help.
I have a 2012 Astra gtc sport with no front foglights. I have bought the following
Astra gtc foglight grills and units
Foglight switch
I need help with the wiring  can anybody please help
1 ground wire and 1 power wire (which is split) but it depends if you have front bumper harness or not as this will determine if you need to run to fuse-board or not.
You will also require programming before they will work.
Insignia B cluster fitted in Astra J milozic 0 1,605 19:th-Jul-2023, 17:25:46
Last Post: milozic
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 29 23,927 12:th-Mar-2023, 15:36:11
  Insignia fog lights retrofit guide zzattack 16 17,401 7:th-Jun-2021, 13:18:53
Last Post: zzattack
  quickheat retrofit WIP Lansa 9 13,208 22:nd-Apr-2021, 21:03:17
Last Post: Lansa
  fit reversing camera on astra j gtc tzr608 23 13,465 14:th-Mar-2021, 20:35:53
Last Post: _Mita
  ASTRA J OEM PARKING SENSORS blacknik 15 12,380 3:rd-Feb-2021, 19:58:42
Last Post: Qaranc
  AFL Retrofit wiring 5-Door ONLY. Rusty2009 29 32,579 31:st-May-2020, 20:38:03
Last Post: Peterrl
  Howto Retrofit TPMS Rusty2009 52 42,853 20:th-Feb-2020, 22:06:39
Last Post: komshija
  How to retrofit flex floor Astra-J (MK6) 5 Door Rusty2009 11 26,707 18:th-Feb-2020, 08:13:37
  Astra J Sport tourer and OEM rear view camera saarits 47 32,184 26:th-Mar-2019, 23:38:23
Last Post: tzr608
4 User(s) read this thread:
marktourino (3:rd-Jun-2023, 07:50:16), M.Duman (30:th-May-2023, 00:17:37), exhippykev (19:th-Jul-2023, 20:37:38), opelmed (28:th-Sep-2023, 15:55:04)
