lights fog insignia guide retrofit
Insignia fog lights retrofit guide
Insignia front fog lights retrofit guide
1. electrical schematics
[Image: sch_thumb.png]
.PDF version here
The S30 headlight switch has a few toggles for the different lights. It connects to the K9 body control bomodule through the 'X3' connector. This BCM is also connected to the P16 instrument cluster, the fog lights in the rear, and of most interest to us, the fuse block that houses the KR46 relay which is used to power the fog lights when they're installed.
The BCM needs a wire from pin 10 of the brown X5 connector on the left-hand side under the wheel (LHD) or below the accessory box (RHD), ran towards pin 19 of the X2 block sat below the fusebox under the hood. The fusebox contains an internal relay that will provide power to fuse 48 when it receives a signal from the BCM to turn on the front fog lights. The output from the 48 fuse can be tapped into on the X1 connector, pin 31. This is the wire that we'll eventually run to the lights in the bumper.
2. parts list
Most of the parts are easily sourced from ebay or common parts stores. Much more difficult is finding compatible crimp pins so it's easiest to cut the connectors out of a scrap car and remove the pins from them, then solder that to the wire you run yourself.
- fog lights left/right (OEM nr. 13226828 and 13226829)
- grill fascias left/right (OEM nr. 1400463, 1400464)
- headlight switch with front fog lights button (OEM nr. 13268702 for LHD, probably different for RHD)
- 2x H10 connector
- 2x H10 bulb
- electrical wire, 1.5mm² or so
- 2x terminal wire for fusebox connector
- terminal wire for BCM connector
3. bumper removal
This is surprisingly easy. There's just 3x T20 screws inside both wheel covers, 6x T20 screws under the hood, and 4 plastic clips underneath. Pull the bumper slightly forward and it pops right off. Disconnect the single connector near the battery and let it rest on some thick cloth or something else that prevents scratching.
[Image: bumper_remove_thumb.png]
4. installing the lights
Next step is removing the old fascia's. They use a push-on system and require a fair bit of force to be pulled out. I used vice grips so I could get a good hold. They're pretty sturdy so no need to go easy. Look at the replacements to see exactly where all the clips are.
With the fascia pulled out you'll be able to see how the chrome decorative strip is attached. These clips are far less tough. Work your way from the flat side toward the rounded part, carefully lifting the clips and pulling the cover outward.
[Image: chrome_strip_detached_thumb.jpg]
When removed, reattach the strip onto the new fascia and install those into the bumper. Now insert the lights. Factory install probably uses another clip for these but any M6/M7/M8 bolt/nut combination will keep it firmly in place.
[Image: m7_bolts_thumb.jpg]
5. bumper inner wiring
When both lights are fitted it is time to prepare their wiring. For this install I've used some 1.5mm² speaker wire. I wouldn't go below 1.0mm² since these lights draw about 12A when powering them on.
You can choose to zip-tie the new wire to the protective tubing for the existing wire (fast method) or you can run the new wire inside the protective tubing, which will take about half an hour to do properly. For the latter method you will need some wire loom tape like they've already used near the junctions. You'll have to remove this tape to be able to feed the new wires through and the tape doesn't stick very well so replacing is recommended.
I ran a single wire from the connector to the grille with some spare length, then I ran another wire on each side toward the fog lights and soldered them together at the point where they split.
[Image: bumper_wire_t-split_thumb.jpg]
Solder them onto the H11 connectors, use some shrink tube to make it all nice and insulated, and finally use wire loom tape to tidy it all up.
[Image: lamp_connected_thumb.jpg]
Finally I chose to add a superseal waterproof connector to the new wires, so that future bumper removal remains easy.
The bumper can now be reattached. Make sure to reconnect the connector and don't leave the new fog lights wires dangling where you can't reach them.
6. fuse block wiring
With the bumper reinstalled it's time to wire them up. There's a few ways in which this can be done. The cleanest way is to crimp a compatible terminal on a new wire that we plug into the X1 block below the fuse box under the hood. Due to these terminals being very hard to source it may instead be easier to remove a block from a scrap car and reuse the wire from there.
[Image: below_fusebox_thumb.jpg]
X50A Fuse Block - Underhood X1.pdf
X50A Fuse Block - Underhood X2.pdf
See the attachments for the precise pin locations. The positive wire for the fog lights connects to fuse 48, for which we can add a pin to the X1 underblock pin 31.
In order to be able to insert the wire in the block, you must pry loose the grey locking plate and eject it. The terminal can then be inserted and will hook into place nicely.
The negative wire can be crimped to a faston connector and bolted somewhere on the chassis.
[Image: faston_thumb.jpg]
7. headlight switch swap
This is probably different depending on whether the car is left- or right-hand drive. Open the small accessory box below the switch and take out the screws that are then revealed. Now the bracket holding the switch simply pulls forward and the switch easily clips out.
8. BCM wiring
This step may not be needed on some cars if the wiring is already in place. While you have the fuse blocks accessible, see if there's a wire in the pin 19 spot on the X2 connector. If so, you're lucky and you should also see the brown connector on the BCM having a brown/white wire in pin 10. If not we will have to run it ourselves, which is a bit annoying and can take a little while.
K9 Body Control Module X5.pdf
In order to run this wire we have to detach the small fuse block that's clipped onto the battery near the positive pole. This allows us to move it out of the way, so that the coolant surge tank can be moved forward a little bit. It shifts over a nodge and once it's moved forward sufficiently, it can be moved out of the way; no need to remove any hoses.
This gives easy access to the huge grommet with all the wiring that goes inside.
[Image: wire_feed_thumb.jpg]
Be careful not to damage any of the existing wiring and pry a little hole with a small screwdriver or similar sturdy object. Since the area is fairly accessible this shouldn't give too much trouble. I already got a 2x6mm² wire through there so a single thin wire should be super easy. Using a nylon draw-in spring this should be very easy.
[Image: draw-in_wire1_thumb.jpg]
[Image: draw-in_wire2_thumb.jpg]
On the other end, route the wire similar to the other wires going toward the BCM and insert a terminal salvaged from a scrap connector into pin 10 of the brown X5 connector.
That concludes the wiring.
[Image: bcm_x5_thumb.jpg]<
9. programming
Unfortunately, this retrofit requires VCI programming of the BCM. If you have an MDI and registered a business on the GME-infotech site you can do it yourself, or else you can bring it to the dealer, which may not even end up being more expensive. I needed 2 SPS sessions (€10 each) and the VCI (category A, €35) so a total of €55. Quite annoying if you ask me, but apparently this is how GM wants it to be.
That's the last of it..
[Image: complete1_thumb.jpg][/img]
Some extra bits added in case they are useful to others.
E29LF Fog Lamp - Left Front (T3U).PDF
E29RF Fog Lamp - Right Front (T3U).PDF
.pdf   X50A Fuse Block - Underhood X1.pdf (Size: 94.49 KB / Downloads: 106)
.pdf   X50A Fuse Block - Underhood X2.pdf (Size: 96.27 KB / Downloads: 75)
.pdf   K9 Body Control Module X5.pdf (Size: 119.46 KB / Downloads: 100)
Handy, but it will be very helpful if they where some pictures
looking at the wire you have circled in the x5 connector that is pin 21... the brown wire, you are saying pin 10 i'm confused,
ok i figured you were marking the pin 10 location, (behind the brown wire pictured)
Can you please send me pictures of the wiring diagram for insignia front fog lights
(10:th-Apr-2020, 09:56:21)Kulitone Wrote: Can you please send me pictures of the wiring diagram for insignia front fog lights
It's the first picture in the OP post.
Do you live near barnsley and would you be able to wire them up for me
Do you live near barnsley and would you wire them up for me
(14:th-Apr-2020, 10:28:42)Kulitone Wrote: Do you live near barnsley and would you wire them up for me
I live in Bournemouth & can do it.
this is great info. shame i cant open the files
(16:th-Apr-2020, 21:29:00)Budd Wrote: this is great info. shame i cant open the files
Just checked the links and they appear to of been removed.
I will get the info and re add it into the OP's post when I get a chance.
Great, thanks
Updated the Links in the OP's original post.
Great, thanks
Guide is very good. Already retrofit on my 14 plate Insignia and friend 66 plate
is the above post spam? I can't access any of the links, and this is the 3rd exact same post by the same OP.
I tried reporting it via the report button, but nothing happened.
Persistent buggers..
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 34 41,419 30:th-Aug-2025, 20:00:16
Last Post: obsidian
  quickheat retrofit WIP Lansa 10 20,460 26:th-Aug-2025, 19:15:09
Last Post: obsidian
Wink Insignia B cluster fitted in Astra J milozic 0 4,112 19:th-Jul-2023, 17:25:46
Last Post: milozic
  AFL Retrofit wiring 5-Door ONLY. Rusty2009 29 47,427 31:st-May-2020, 20:38:03
Last Post: Peterrl
  Howto Retrofit TPMS Rusty2009 52 70,363 20:th-Feb-2020, 22:06:39
Last Post: komshija
  How to retrofit flex floor Astra-J (MK6) 5 Door Rusty2009 11 37,080 18:th-Feb-2020, 08:13:37
  Retrofit Rear Power point 5 door Astra J Ballinlea 3 15,378 20:th-Mar-2019, 18:13:44
  Single to dual horn upgrade retrofit Lansa 13 22,848 27:th-Jul-2018, 11:20:55
Last Post: Lansa
  Astra gtc retrofit foglights Daniel199025 1 6,968 19:th-Jul-2018, 07:32:40
  Bluetooth retrofit wiring tzr608 9 14,567 18:th-Jul-2018, 19:13:21
Last Post: tzr608
3 User(s) read this thread:
Qaranc (8:th-Aug-2025, 20:15:02), husky (3:rd-Apr-2026, 22:15:00), jas7c5-2008 (11:th-Jan-2026, 13:42:11)
