gtc foglights astra retrofit
Astra gtc retrofit foglights
 Guys need help.
I have a 2012 Astra gtc sport with no front foglights. I have bought the following
Astra gtc foglight grills and units
Foglight switch
I need help with the wiring  can anybody please help
1 ground wire and 1 power wire (which is split) but it depends if you have front bumper harness or not as this will determine if you need to run to fuse-board or not.
You will also require programming before they will work.
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 34 41,117 30:th-Aug-2025, 20:00:16
Last Post: obsidian
  quickheat retrofit WIP Lansa 10 20,387 26:th-Aug-2025, 19:15:09
Last Post: obsidian
Insignia B cluster fitted in Astra J milozic 0 4,068 19:th-Jul-2023, 17:25:46
Last Post: milozic
  Insignia fog lights retrofit guide zzattack 16 25,465 7:th-Jun-2021, 13:18:53
Last Post: zzattack
  fit reversing camera on astra j gtc tzr608 23 25,312 14:th-Mar-2021, 20:35:53
Last Post: _Mita
  ASTRA J OEM PARKING SENSORS blacknik 15 20,714 3:rd-Feb-2021, 19:58:42
Last Post: Qaranc
  AFL Retrofit wiring 5-Door ONLY. Rusty2009 29 47,289 31:st-May-2020, 20:38:03
Last Post: Peterrl
  Howto Retrofit TPMS Rusty2009 52 70,092 20:th-Feb-2020, 22:06:39
Last Post: komshija
  How to retrofit flex floor Astra-J (MK6) 5 Door Rusty2009 11 36,972 18:th-Feb-2020, 08:13:37
  Astra J Sport tourer and OEM rear view camera saarits 47 57,309 26:th-Mar-2019, 23:38:23
Last Post: tzr608
