headlights aftermarket
Aftermarket headlights
Hi was wondering if anyone knows if the headlight leveling motors out my existing headlights will fit these aftermarket ones as the company said they would but I would have thought it would have been different wiring to to the motor feed coming from the headlight it self haven't look at my original ones yet as I need to change them due to driver side badly condensating was looking at these headlights.
https://www.energizedcustoms.co.uk/shop/...gLz1fD_BwE
IIRC when @Sheppy1 looked into buying aftermarket lights the leveling motors are built inside the factory headlights and it would of cost him an extra£40-50 to buy them separate,
Yo! It would have with that seller yeah, another seller said they came included in the units and were the same headlights as well
Sent from my LG-H870DS using Tapatalk
No problem do any of you know where the best place to get aftermarket lights with levelling? As like the led strips with projectors. As below is my current headlight got a retrofit done by a company in Scotland and he tried to plastic weld them which split eventually so had to sikaflex them but still no good now gradually getting worse and they are out of warranty as you can see one of the photos shows the split, so just going to bite the bullet and try and get a decent set of aftermarket projector lights just now if any of you know anywhere or recommendations.
I’d dry them out and use some headlamp sealant.
Best place to of cut them is the front (where the clear cover meets the back).
No problem maybe give it another attempt to try and fix them as they do look nice when they are dry as below, lost count now to how many times I have dropped the bumper now for these lol.
This is what you'd want
https://www.ebay.co.uk/itm/BUTYL-RUBBER-...1438.l2649
& put a couple of sillca packs in each lamp also which will help.
http://www.ebay.co.uk/itm/0-5g-1g-5g-10g...BH8SBDbCyw
  Dipped Headlights queries Michael C 1 761 26:th-Dec-2023, 13:07:38
  Headlights Peterrl 3 2,173 12:th-Jul-2020, 07:26:51
  Aftermarket android H5754 headunit issue simpledun 1 2,682 4:th-Jun-2020, 09:17:15
  Aftermarket headunit malfunction prtklmb 2 2,209 28:th-Apr-2020, 09:08:35
Last Post: prtklmb
  Astra gtc headlights to Astra j leemallin 2 3,073 14:th-Feb-2019, 15:42:54
Last Post: vjeko::..
  Headlights Mspencer 1 2,193 25:th-Jan-2019, 08:34:00
  LED Headlights Martz66 0 2,151 26:th-Oct-2018, 17:22:01
Last Post: Martz66
  Upgrading my headlights Mspencer 12 6,056 27:th-Sep-2018, 22:49:38
  Headlights Mspencer 3 3,533 17:th-Apr-2018, 22:14:03
Last Post: Mspencer
  Astra j updated headlights Rmc 10 7,172 5:th-Feb-2018, 11:44:31
Last Post: JETHRO54
