headlights my upgrading
Upgrading my headlights
Hi all I’m upgrading my headlight to projects so I can use led bulbs with the correct beam pattern and was wondering witch to go for I’ve seen a few on eBay has anyone got a set they could recommend
Thank
What recommendation do you want?
The headlights or the bulbs?
Headlights them selves please
Are you looking at buying a set that’s aftermarket or modifying your own headlights
Not sure witch yet trying to fine witch is the best option for the price
There is 2 sets of aftermarket lights, they did put up a write up on them on here so could be worth a look for that.
(9:th-Sep-2018, 08:40:51)Rusty2009 Wrote: There is 2 sets of aftermarket lights, they did put up a write up on them on here so could be worth a look for that.
I'm being a bit thick today Rusty, where can I find that write up that mate?
Had to hunt for it myself.
https://www.vxoc.org.uk/forum/Thread-Pro...3#pid13333
From within this thread, I know he did sell the car so I don't think he's an active member anymore.
https://www.vxoc.org.uk/forum/Thread-Pro...dan-Naylor
Thanks Rusty
Need a little help...
Just picked up a set of those aftermarket headlights in Jordan's thread.
When I spoke to my local garage about getting them installed they were adamant that they are incompatible because of the LED DRL and that the projectors were an immediate MOT failure?
I actually spoke to the company before I purchased them, and they assured me they would be error free and pretty much plug 'n' play, which was supported by Jordan's thread.
As I don't have the tools or the talent to do something like this myself, I'm pretty much at a loss.
The LED's will have resistors which will stop the error's and they will works.
I can't see your fail an MOT there is no reason to fail an MOT with them fitted.
(26:th-Sep-2018, 06:46:47)Rusty2009 Wrote: The LED's will have resistors which will stop the error's and they will works.
Thanks Rusty. I didn't understand why they would fail the MOT either, which is why I was a bit confused. I didn't know the LED's had built in resistors but that would be logical.
I got the impression that they weren't really interested in fitting them and were trying to fob me off. I don't suppose you know anyone in the Midlands that could do it for me? Thanks
they are probably getting confused - as the regulations have recently changed.
I think they can now fail if youv'e fitted different bulbs
the testing manual states
"Existing halogen headlamp units shouldn't be converted to be used with HID bulbs. If such a conversion has been done, you must fail the headlamp."
but if youv'e fitted new lamps I think you should be OK (but I'm not a tester)
  HID Bulbs for GTC projector headlights eatmybogbrush 1 2,146 7:th-Mar-2025, 08:57:08
  Dipped Headlights queries Michael C 1 3,268 26:th-Dec-2023, 13:07:38
  Upgrading the CD400 sadiqr10 0 5,306 11:th-Nov-2020, 04:58:09
Last Post: sadiqr10
  Headlights Peterrl 3 4,774 12:th-Jul-2020, 07:26:51
  Astra gtc headlights to Astra j leemallin 2 6,743 14:th-Feb-2019, 15:42:54
Last Post: vjeko::..
  Headlights Mspencer 1 4,811 25:th-Jan-2019, 08:34:00
  LED Headlights Martz66 0 3,650 26:th-Oct-2018, 17:22:01
Last Post: Martz66
  Headlights Mspencer 3 5,658 17:th-Apr-2018, 22:14:03
Last Post: Mspencer
  Astra j updated headlights Rmc 10 12,717 5:th-Feb-2018, 11:44:31
Last Post: JETHRO54
  Aftermarket headlights Iaintruten 6 7,645 5:th-Nov-2017, 09:01:07
