issue esp service
Service ESP issue
I have service ESP message showing on the dashboard along with the ABS symbol and car with 2 lines underneath symbol. Borrowed and connected a Bosch KTS 200 diagnostic tool to it and it showed up as error code C0040 Wheel Speed sensor front right malfunction. Bought a new front sensor and fitted quite easily myself but I am no expert with the diagnostic tool. I think I cleared the error memory as the lights and ESP warning message went off but as soon as I gave the KTS 200 back the warnings return and the brakes feel like they are grinding again when used at very low speed. I take it that is the result of the ABS kicking in when not required? Seems fine at higher speeds. Question is do I try and clear the fault properly on the BOSCH diagnostic tool again or just bite the bullet and put it into the garage to do properly?
Any advice welcome :-)
Mark
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 8,958 29:th-Aug-2018, 07:27:16
  JTC 1.4T (Automatic Gearbox) Downhill issue MeshyMore2 2 6,920 22:nd-Nov-2017, 17:16:20
Last Post: MeshyMore2
  Service Vehicle Soon (sorry) c.barker64 6 14,100 23:rd-Oct-2017, 11:18:52
