issue drl
Drl issue
Hi guys after noticing my drivers side DRl not working I replaced  the bulbs. However the drivers side drl is still not working even though the sidelight is. Any ideas
I had that once found locking the car and leaving it for a few hours sorted it.
Is the bulb definitely dual filament?
Hi yes defiantly dual filament it's only the drivers side that the drl doesn't work however when you switch the sidelights work on both??
Try switching bulbs from one side to the other, if the bulb from passenger side does not work in the drivers side then it could be wiring, if it does work then it is the other bulb.
  2010 Astra J - Cooling Fan issue Madal101_uk 3 3,765 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,044 22:nd-Feb-2021, 08:08:37
  Another blower issue.. Zcubed 25 28,678 4:th-Jul-2020, 13:19:48
  Blower issue Lewis6317 61 68,236 13:th-Apr-2017, 09:26:59
Last Post: Jerry
  coolant issue Shorty S91 5 8,961 8:th-Jan-2017, 22:51:27
Last Post: stigeye
  Airflow issue? Dookified 5 12,333 30:th-Oct-2016, 19:43:44
Last Post: Dookified
  Radiator Fan and Service TAG Issue Roden 10 16,158 8:th-Jun-2016, 19:44:47
Last Post: Roden
