dabs unit signal head android
dabs signal , android head unit
guys ive been studing forums everywhere to get some info on the signal problems whilst using the window mounted antenna that are to be used with the dabs usb modules for android head units.
i fitted this unit
https://www.aliexpress.com/item/HD-1024-...0.0.JesoCG
and had to get the dabs module to suit with antenna
http://www.ebay.co.uk/itm/Digital-DAB-Ra...2103629555
problem is when all is said and done the signal from these antennas is absolutely rubbish.
i have been reading that only a passive antenna could be used with these modules as an alternative
http://www.dabonwheels.co.uk/Budget_Hirs...erial.html
has anyone else had similar problems with a different solution...?
(28:th-Aug-2017, 15:51:35)buttonsni Wrote: problem is when all is said and done the signal from these antennas is absolutely rubbish.
Yep window mount antennas are terrible.
(28:th-Aug-2017, 15:51:35)buttonsni Wrote: i have been reading that only a passive antenna could be used with these modules as an alternative
Very most likely not true.
If I were you I'd fit the original antenna amplifier. Have a look in the DAB retrofit how-to threads for more info. The in-glass antenna DAB reception is really excellent for me, and all you'd need is the amplifier plus some coax cable.
i have an astra gtc , and the oem shark fin is for gps which i never had.
however i have traced back the black fm and blue dabs Aerial back to the side windows for the fm and i see the dabs blue cable on the drivers side back quarter panel pillar.
both these Aerials have amplifiers attached to the car panels and power connecting to them...
i was told the dabs usb module for android can not work with amplified aerial.
zzattack..i have 2 antenna in the back quarter panels glass....but i think both are fm stereo.
the blue connector which is dabs is on the pillar between the glass and the boot lid...
but i can only see a connection out......not a connection in ..and power going to the booster...
hows does this gtc 2.0 2012 model receive the Dabs signal????
there is only a brown connector at the roof as far as i can see...
have you any thoughts on this????
much appreciated!!
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 184,870 20:th-May-2021, 09:19:58
Last Post: h4r7y
  How to Install aftermarket head unit Rusty2009 55 88,771 14:th-Mar-2021, 15:16:56
Last Post: GTC-Nut
  Android RV5754 factory settings password Amazingusername 3 6,382 7:th-Nov-2020, 16:08:03
Last Post: cro55m
  Battery drain Android tesla style head unit rayvo1 4 8,086 9:th-Sep-2020, 21:05:31
Last Post: rayvo1
  Sports Tourer DAB+ on Android Headunit MikeyP247 2 5,589 2:nd-Nov-2019, 17:11:28
  Dash cam on Android unit robk999 2 12,625 2:nd-Nov-2019, 10:30:30
  CD400 buttons not working Android head unit install mephisto 4 12,542 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  Front DVR android S160 M072 NEATH-LAD 3 6,191 4:th-Jul-2019, 19:07:39
  How to Install Android Head Unit + Wireless Reverse Camera sheppy1 64 72,545 9:th-Jan-2019, 15:07:53
Last Post: Shorty5
  after market head init marky79 0 7,081 4:th-Nov-2018, 17:17:12
Last Post: marky79
