pdc vxr bumper front on
PDC on VXR front bumper
Just ordered a complete VXR front bumper. It dosen´t have PDC option. PDC was not an option on the VXR.
Mine comes from factory with PDC. Has anybody fitted the PDC sensors in this bumper and where.
Maybe someone has a good idea how to fit the sensors.
All inputs are welcome.
The bumper should have making inside showing where the holes are to be drilled.
Also you would need to buy the repair brackets and have them bonded onto the bumper.
(8:th-Apr-2017, 21:33:16)Rusty2009 Wrote: The bumper should have making inside showing where the holes are to be drilled.
That would be great if there were markings on the backside, like on all the other bumpers. But I am not sure there are any, as the VXR didn´t have front PDC as a factory option. I guess I will have to wait and see.
If Not just use your bumper as a guide.
I have now got the VXR frontbumper. There are no markerings for PDC and I can not use the old bumper as a guide because, where they are seated now on the standard bumper, On the VXR bumper there is no plastic to put them in and the holes are much bigger for cooling and brakes..
Front parking sensors are not fitted to the VXR, only rear ones.
You'd have to place them somewhere else on the bumper then.
(9:th-May-2017, 22:23:08)srea064 Wrote: Front parking sensors are not fitted to the VXR, only rear ones.
I am aware of that as I wrote it in the #1 post.
"It dosen´t have PDC option. PDC was not an option on the VXR."
  Retrofit front parking sensors (GTC) pedroc1999 3 2,414 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,746 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,627 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Front PDC wiring diagram milozic 1 2,520 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 8,258 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 3,410 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 3,104 12:th-Jul-2020, 07:37:10
  BiTurbo Rear Bumper Dudderz 3 2,511 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 2,215 13:th-May-2020, 14:56:05
Last Post: paula9568
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,846 25:th-Apr-2020, 07:41:05
milozic (18:th-Sep-2023, 21:09:09)
