passenger seat parts for
Parts for passenger seat
I'm after the spring that goes on the adjuster handle of the front seats. It's the handle you lift to slide the seat backwards and forwards. The spring goes between the handle and the locking mechanism on the runner.
I'm also after the part numbers for the threaded torx bolt (I think it's an m6) and the nut the goes with it which bolts the runner to the seat frame.
Hopefully that makes sense?
I'll have a look over the weekend.
But I think you may find the spring comes as part of a complete unit.
Cheers Russ
I've attached a .pdf of the seat parts no springs are listed, but see if you can spot the part you need.
.pdf   seat.pdf (Size: 295.63 KB / Downloads: 9)
Shocked Spare Parts carlos180 1 6,284 18:th-Nov-2018, 09:26:52
  Back-order parts through garage JackDako 3 6,792 5:th-Apr-2018, 08:39:19
Last Post: JackDako
  GTC seat in J jj120979 5 7,566 29:th-Jun-2017, 08:52:21
