pedal clutch j astra loose
Astra J Clutch pedal loose
If noticed that the clutch pedal feels loose.
I can wiggle it left to right very easily.
Is this a common problem?
Can it be fixed?
A squeaky pedal is common, think your find it'll be a new pedal assembly.
Thank you for your help.
Should I only order a new pedal then, or other pars as well?
You'd most likely need the whole assembly
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...SwWxNYwB1j
Okey.
Is it a lot of work to replace it?
(9:th-Mar-2017, 08:35:50)abba34 Wrote: Okey.
Is it possible to change the clutch pedalen prins for a less strong one?
I had the same problem with clutch pedal on my astra J 1.4 turbo. Bought new one and everything works great
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,667 12:th-Sep-2021, 15:24:05
  Brake pedal sensor learn. Richiew1986 0 1,311 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,116 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 4,117 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,899 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,915 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,064 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,188 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,526 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,840 24:th-Jan-2021, 14:44:22
