selecting up showing options general error when
Error showing up when selecting General options
Tested in IE, Firefox and Chrome. Get the following issues when selecting "Forum Actions"-> "General Settings" you get the following error
"Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: userfield_select_option in [path]/includes/functions.php on line 4734
P**** error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(23) : eval()'d code on line 1
Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: userfield_select in [path]/includes/functions.php on line 4734
P**** error: syntax error, unexpected T_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(26) : eval()'d code on line 1
Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: userfield_textbox in [path]/includes/functions.php on line 4734
P**** error: syntax error, unexpected T_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(43) : eval()'d code on line 1
P**** error: syntax error, unexpected T_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(59) : eval()'d code on line 1"
I'll have a look into it later.
I get the same, using chrome here. HTH
Thanks guys all fixed now I forgot to remove some code from the config file after using it to find another fault the other day.
  Error when opening tabs Cameron UK 9 8,033 4:th-Aug-2014, 09:40:57
  Copy and paste error message cornishtaz 2 5,469 15:th-Apr-2014, 14:54:17
TrealdUnrem (9:th-Apr-2024, 15:40:35)
