JohnL - Replies:
Error showing up when selecting General options
Tested in IE, Firefox and Chrome. Get the following issues when selecting "Forum Actions"-> "General Settings" you get the following error
"Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: userfield_select_option in [path]/includes/functions.php on line 4734
P**** error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(23) : eval()'d code on line 1
Warning: fetc
New LED DRL's showing numerous faults
I have fitted (as per Tucpal's 'How to LED DRL error free' guide) but I am having a headache with faults that have thrown up. I have installed the resistors, wiring and Scotchlok clips and LED bulbs correctly. Firstly, the left DRL will light intermittlently but it will light on the sidelight OK.
And now the following faults show intermittently:
Check left dipped beam lamp
Check right dipped beam lamp
Check left Daylight running lamp
Check right Daylight running lamp
When the lights are swi
How-to fix image and video showing as links
How to image and video showing as links.
You need to click on "User CP",
Then go to "Edit options",
[ali
