j seat vxr astra front
Astra j vxr front seat
Hi newbie on here so b nice to me
I have a 2013 vxr and the the passenger seat folding hinge has just snapped on me so can't get into the back
I have bought a replacement hinge and have taken out all of the plastic bits around the area but can't get any further
Do you have to remove the back of the seat and take off all the leather or can it be done from the small hole where the handle is located
Any help would be appreciated
@cornishtaz maybe able to help here
When my passengers handle broke the mechanism inside snapped and to get to it you've got to strip the seat back down. This is a known design fault and should be fixed under warranty.
You can still get in the back by using the tilt and slide handles you use for seat adjustment
Cheers for that
Do you have to take the seat out and take the back off or can you just do it in the small space that's there
It's in at Vauxhall for MOT next week and pretty sure it will fail on this fault
Complete seat out to strip it down.
???? Ringing Vauxhall to see how much it will cost for them to do it if to much will give it a shot in the week
Will post progress
Tnx again
MOVED LOCATION
Do you have any solution for this?
  Retrofit front parking sensors (GTC) pedroc1999 3 2,365 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,541 12:th-Sep-2021, 15:24:05
  Lowering springs identify front rear martinpe68 1 1,681 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,077 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,585 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,807 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,898 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,030 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,160 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  VXR Seat (not the handle) Bigsmokeuk 1 1,842 12:th-Feb-2021, 11:16:57
Last Post: killboy
